Trip Odometer resets?
Old Jun 26, 2008 | 02:32 AM
BlackHawk04's Avatar
rubber side down
BlackHawk04 is on a distinguished road
Hey gang, I searched for a thread but couldn't find any regarding Trip Odometer.
Nothing electrical is amiss on my bike. There is this one flaw regarding the odometer. About 2-3 times during the tank the odometer will reset after I turn the bike off and start it again after a few hours or a few days.
I know it is a non-essential item, but seeings how I've got everything else running well, I have to noodle with this. All of the connections a secure and seem to be free of foul. Anybody know what might be causing this??
Thanks!!
Old Jun 26, 2008 | 05:07 AM
drew_c14's Avatar
Could it be the button itself? Does it ever change between A and B on it's own?
Old Jun 27, 2008 | 01:45 AM
rubber side down
No that isnt the case, but a good observation. In fact I have to really lean on the thing to get it from A to B. I'll be mindful of the suggestion though thanks.
Any other thoughts??!!
Old Jun 27, 2008 | 02:57 AM
ripvanwinkle's Avatar
aka sirch345. vtr1000.org
ripvanwinkle is on a distinguished road
I don't know if this is going to help you, but I thought I'd mention it anyway.
A mate of mine had a similar problem after fitting an alarm/immobliser. The problem was the immobliser, when the bike was in an immoblised state all the power was cut from the speedo and rev counter pod. Apparently the trip odometer needs a small power supply when the engine is turned off to run it's memory.
Chris.
Old Jun 27, 2008 | 03:46 AM
This wont help but if it makes you feel any better I once had a tripmeter that would also randomly reset itself to zero when I turned the bike off...do not know why...
Old Jun 27, 2008 | 04:51 PM
rubber side down
Thanks for the ideas. I dont have an alarm, BUT I did install some grip heaters which may be the culprit. Thanks for the idea!
Old Jun 27, 2008 | 09:21 PM
Does the clock lose time also?
I had that happen with my new 1990 Trooper. Dealer setup had forgotten to transfer a fuse. Check all fuses.
Old Jun 28, 2008 | 05:10 AM
rubber side down
It does in fact loose time.... Checking fuses at sun up, thanks for the tip!
Old Jun 28, 2008 | 08:39 AM
superbling's Avatar
If your clock is also resetting, you definitely had an electrical supply issue. I hate to say it but that's one sign of R/R failure. Check it out too.
513mugsy
Apr 10, 2012 06:22 PM
roisman
Jun 15, 2011 12:36 AM
Grasshopper
Jun 30, 2010 02:24 PM
inderocker
Dec 24, 2008 08:52 AM
mikecronis
May 21, 2006 09:49 AM
