Think CCT is going..?
Old Nov 30, 2006 | 09:49 AM
malken00's Avatar
malken00 is on a distinguished road
Just wanted to confirm, I've read a LOT here about the CCT's going. My SHawk has 8300 miles on it, '03. It did sit for awhile though, about a year and a half.
When riding for awhile consistent RPM's, then I let off the throttle (leaving it in gear) and hear a rattle from the engine bay, which is consistently week to week getting worse.
This the CCT everyone think?
Thanks!
Old Nov 30, 2006 | 10:44 AM
This would be very low mileage for a cct to go out but anything is possible. The FIRST thing I would try is an oil change. Refill with Rotella (either) no need to go synthetic right away. Burn 500 miles and see if it doesn't improve. Simple thing but has worked for me - valve train noise, sticking or sticky transmissions, funky clutch noises - it's worth a try!
Old Nov 30, 2006 | 02:01 PM
Lefin102's Avatar
You might try to listen with a stethoscope and see if you can't narrow down the location in the motor where the noise is coming from. Worth a try you can get one at auto tools supplier. Good luck post your findings.
Old Nov 30, 2006 | 03:04 PM
malken00's Avatar
Thanks for the input
Surprisingly, it doesn't make the noise without the transmission in gear. And only on winding down from riding for a bit, never just revving in the garage.
Possibly the transmission I'm thinking, now.
Old Nov 30, 2006 | 03:12 PM
iscoot's Avatar
iscoot is on a distinguished road
clutch plates. seems to me?
Old Nov 30, 2006 | 03:25 PM
HRCVTR1000's Avatar
When you pull in the clutch does it stop? Might be typical noisy Honda clutch basket . Seems that all my Hondas do it . VFR, CBX & VTR.
Old Nov 30, 2006 | 08:35 PM
BeerHunter's Avatar
Slacker
Check the condition of the drive chain. If it is unevenly stretched or binding on a few links, this could be your problem. Possibly a good lube and proper tension could solve this problem (hopefully). Just a thought...
Old Dec 3, 2006 | 10:44 AM
malken00's Avatar
It does seem to stop with the clutch pulled in... I also noticed it is time to replace the drive chain.
Thank you all for sharing your experience! I think my CCT's are happy for now.
Auron
Apr 17, 2014 07:18 AM
j shizzy wizzy
Aug 10, 2013 04:00 PM
chemomche
Jul 30, 2012 05:40 AM
kenhawk
Sep 2, 2008 01:37 AM
dpenix76
Sep 18, 2006 08:43 PM
