Suddenly Starts in nuetral only...
Old Jun 3, 2009 | 09:21 AM
j_bud2007's Avatar
j_bud2007 is on a distinguished road
98'... It was running like a champ, Backfired while driving on the freeway and died. It now only will start in nuetral, when I try to put it in gear it dies. I checked the fuses and they look good. The wiring at the kickstand had some grease/oil in and around it. I suspect there is some kind of short. Someone told me there is a switch I need to access to start the bike. Any suggestions to get it in gear?
Old Jun 3, 2009 | 09:29 AM
VTRumble's Avatar
sounds like the sidestand switch, does the light stay on when the stand is up?
Old Jun 3, 2009 | 09:37 AM
j_bud2007's Avatar
In Nuetral the "N" light stays on when the kickstand is up or down. When I put it in Gear it dies and the engine light goes on. It seems strange that the switch would go out as i'm riding the bike. Is there an overide? or an easy way to verify that it is the switch is out? or do I have to buy a new switch and replace it and go from there?
Old Jun 3, 2009 | 09:53 AM
Cleveland's Avatar
Post Whore Junior
The switch might just be gummed up with grease and road grit.. The "N" light is the neutral light.. the amber light beside it is the side stand light.
Old Jun 3, 2009 | 10:00 AM
j_bud2007's Avatar
I'll have to go and check the Light. The bike is in a parking lot. I am going to clean the connections etc... and check the wiring with a meter. I was told it may be the bank sensor and that it might need to be reset. I just don't know where the bank sensor is located. Any ideas?
Old Jun 3, 2009 | 10:18 AM
I have never heard of a bank sensor on our bikes... Don't think it has one.
But it probably is just the kickstand (sidestand) switch together with your dash light for that switch being burned out. (since your symptoms perfectly describe a malfuctioning kickstand switch)
Old Jun 3, 2009 | 10:36 AM
j_bud2007's Avatar
Now that you mention it, I don't think I saw the amber light come on at all after this happened. I'll have to go check that out. Appreciate the help. I'm gathering the bike will not go into gear at all until i replace the kickstand switch... and possibly the bulb and wiring? No workarounds?
Old Jun 3, 2009 | 10:44 AM
Try shorting the kickstand switch with a male to male spade wire. (as is done for racing)
Unless you crashed I really doubt the wiring is bad.
Old Jun 3, 2009 | 11:55 AM
LineArrayNut's Avatar
I could ride in
The bank sensor on our bikes is...
2 of them !
The hero pegs! lol
the manual even gives a torque value for them, lol!
Old Jun 3, 2009 | 11:58 AM
2 of them !
The hero pegs! lol
Lol, then mine are ground down a bit too much, especially the left one post my accident.
Old Jun 3, 2009 | 12:28 PM
j_bud2007's Avatar
ok... The kickstand light works and goes on and off when the kickstand goes up and down. Disconnected the connector under the seat and shorting the male to male connectors. It would trigger the kickstand light, but the same thing still happens when I try to put the bick in gear (shuts off). Then my battery died (ugh!) I'm charging the battery right now. Help! any other suggestions. Like how to reset the Bank sensors (if there are any?) I need the bike to get to work tomorrow. Anyone?
Old Jun 3, 2009 | 12:30 PM
Well there are no bank sensors. And you want the kickstand light off to be able to ride. (if light is lit then bike will die in gear)
Old Jun 3, 2009 | 12:38 PM
j_bud2007's Avatar
Funny thing tho. In Nuetral and started If I put the kickstand up, the light does go off. I put it in gear and the bike shuts down.
Old Jun 3, 2009 | 12:59 PM
j_bud2007's Avatar
Could it be the clutch switch?
Old Jun 3, 2009 | 01:02 PM
Worth checking, though I am not sure when that switch comes into play.
Old Jun 3, 2009 | 01:05 PM
Cleveland's Avatar
Post Whore Junior
ok, it sounds like it is in the side stand switch.
Start in neutral with stand down (amber light on?), bike runs. Put it in gear with stand down(amber light on?), it dies. Put it in gear with stand up(amber light on?), it dies. The light should go off if the side stand is up, but the stand may be loose.. and vibrating thereby activating the switch.
The side switch is wired to kill the motor if it is down, and the trans is in gear. clean the switch, it should be located at the pivot point on the side stand. You'll see a bunch of gunk, use brake cleaner and a brush.
and yes it could be the clutch switch if there is one..
Old Jun 3, 2009 | 01:08 PM
Yes there is a clutch switch. (I know I hooked it up to my new Master Cyl)
Thing is, the light does go off when he puts the sidestand up. So the switch is at least somewhat working. It may be vibrating though as you mentioned.
J_Bud: Does it die immediately?
Old Jun 3, 2009 | 01:11 PM
j_bud2007's Avatar
Thanks for the advice. There is a bunch of dirt and debri there. I will try that.
Old Jun 3, 2009 | 04:23 PM
Try shorting out the clutch switch, it's by the handle on the bars, two small connectors... Just use a small wire and wrap around both of them...
Old Jun 3, 2009 | 06:36 PM
j_bud2007's Avatar
Yes!!! I took off the kickstand switch and rotated it a couple of times and straightened out the wires. It started. Right now I zip tied it up out of the way. I'm gonna clean it up on the weekend, maybe order a new one all together. $50. Thanks for your help!!!
Old Jun 4, 2009 | 02:20 AM
BeerHunter's Avatar
Slacker
Reference
Have a look at This Old Thread for a little clarification.
Old Jun 25, 2009 | 12:51 AM
I could ride in
Yes there are.
The hero pegs.
Seriously, that's what Honda calls them. It's in the service manual. Promise.
Skoal
May 17, 2016 07:41 PM
Paradisd
Apr 24, 2009 02:35 PM
djkaoscc
Aug 27, 2008 10:05 AM
Chuey
Apr 1, 2007 07:38 AM
USAFrider
Dec 26, 2005 06:33 AM
