Stock piston weight?
Old May 15, 2009 | 06:24 AM
Anyone know the weight of a stock piston? I thought someone had listed it on here previously but my searches (yes, I serached before posting) came up empty. I ask as my new JE`s are listed at 390 g (0.5 mm OS, with skirt and top coating) and I wondered how they compared.
cheers
Old May 15, 2009 | 07:07 AM
killer5280's Avatar
I didn't weigh them, but I noticed when I did my piston swap that the stockers are quite a bit lighter.
Old May 15, 2009 | 08:08 AM
RCVTR's Avatar
Here's what I got when I weighed mine (stock vs. std. bore JE's):
Stock piston: 402.5 g
JE piston: 388.4 g
Stock wrist pin: 130.4 g
JE wrist pin: 117.6 g
Old May 15, 2009 | 08:12 AM
Thanks
so the weight difference is rather small, I was expecting more than that to be honest. At least it`s in the right direction (lighter).
P.S. just to be clear, you are referring to the VTR and not the RC right?
Old May 15, 2009 | 08:29 AM
killer5280's Avatar
JE piston: 388.4 g
I'm surprised. I'll have to weigh the stockers to see what mine weigh, but I swear in a side by side very unscientific comparison the stockers seemed lighter.
Old May 15, 2009 | 08:31 AM
maybe the lower density of the cast pistons makes them seem that way, lol
Old May 15, 2009 | 08:50 AM
RCVTR's Avatar
Yes. Those were Super Hawk pistons
Old May 15, 2009 | 09:13 AM
great, thanks again!
Old May 15, 2009 | 02:50 PM
Firestorm996's Avatar
Another OCMD victim...
If you dont mind the money, throw in a set of Ti wrist pins and save even more weight.
Old May 15, 2009 | 02:58 PM
If I knew where to find some I might give it some thought....
Old May 15, 2009 | 03:03 PM
http://www.angelfire.com/biz5/traunerotiwristpins/
Old May 15, 2009 | 03:08 PM
this link give you a idea about the weight......
http://www.tipro-fasteners.com/Mp.html
Old May 15, 2009 | 03:50 PM
Thanks Peter. I just did a quick search and found info showing that, while lighter, they are not as durable so I'll pass as I plan to ride the bike for many years to come, and don't want to be opening it up to replace a wrist pin every year.
Old May 15, 2009 | 04:53 PM
RCVTR's Avatar
The way to lose weight from the rotating/reciprocating mass is with rods.
Stock VTR rods weigh 560g - 1120g total
Carillo RC51 rods weigh 480 g - 960g total.
A similar amount will be removed from the crank, after balancing.
I'm almost certain Carillo will still manufacture VTR rods. Dynoman Performance (dotcom) sells them for less than Carillo will sell them to the public.
Old May 16, 2009 | 05:44 AM
gboezio's Avatar
Are you taking some weight off the counterweight or leaving it a tad overbalanced ??
It should be ok still,I guess it depends if you pull out the crank, it's definitely not the same job.
Old May 16, 2009 | 05:58 AM
Crank will definitely be coming out as the cylinders will need to be bored 0.5 mm
Old May 18, 2009 | 08:48 AM
RCVTR's Avatar
You can get away with not balancing with a piston swap. It is a small change to the reciprocating mass.
Rods would definitely require lightening the counterweights. They make a big change to the rotating and reciprocating mass.
Old Feb 28, 2010 | 05:55 AM
VTaRse's Avatar
aka tony.mon, vtr1000.org
VTaRse is on a distinguished road
Are RC 51 SP1/2 pistons worth exploring?
They're 2mm diameter larger, don't know if the bores will take that without distorting.
And are they higher comp that Superhawk standards?
Old Feb 28, 2010 | 12:16 PM
Different piston pin diameter. There is also the matter of the deck height....
HawkRider98
Oct 11, 2011 08:12 AM
20_rc51_00
Jul 21, 2011 06:20 PM
uchi
Sep 20, 2010 08:54 PM
tremaineiz
Apr 29, 2007 10:15 AM
captainchaos
Jan 23, 2007 03:51 AM
