Speedometer issues
Old Sep 4, 2016 | 07:39 AM
Rocket Rider's Avatar
Rocket Rider is on a distinguished road
Speedometer issues
Has anyone had issues with there speedometer turning off and on while driving?
Old Sep 4, 2016 | 07:42 AM
Aquasnake's Avatar
Only when the stock reg/rec was taking a dump.
Old Sep 4, 2016 | 09:20 AM
Yup, use a multimeter and check your R/R (Regulator/Rectifier). A bad R/R has been known to completey fry the dash, so check it sooner than later.
Old Sep 4, 2016 | 01:03 PM
Wicky's Avatar
Also if speedo sensor lead is on the way out.
Old Sep 4, 2016 | 04:57 PM
There have been issues with the cluster losing signal and speedo dropping out. My old 98 did this in wet weather, or sometimes after washing the bike. I never did track down the issue as it kept fixing it self before I could trouble shoot it to the end.
Old Sep 4, 2016 | 05:14 PM
I'd check the regulator. Check voltage across battery with bike off, then with bike running to see if the charging system is working.
This is why I installed an in dash voltmeter so I could see if it ever drops.
Worth its weight in gold.
Old Sep 4, 2016 | 05:15 PM
Oh and if its not that, unplug the 2 dash plugs (behind the dash) and spray them with contact cleaner.
happytrack44
Oct 27, 2007 05:26 AM
wardo996
Mar 21, 2007 10:20 AM
roisman
Feb 9, 2007 06:55 PM
98VTR
Jun 16, 2006 11:42 AM
swordfish
Sep 23, 2005 03:48 PM
