something not right
Old Sep 9, 2012 | 11:49 PM
99superhawk_Dom's Avatar
99superhawk_Dom is on a distinguished road
Question something not right
I just replaced all 4 valves on the rear cylinder and it atarted on the firat try but it doesn't sound tbe same. It seems louder and it back fires more. It still pulls the front wheel up but seems to hesitate or not accelerate as quickley when accelerating from 3 or 5k rpms at . Could i have piy it back together incorrectly or do i just need to re-tune the carbs. This is the first time that i have taken it that far appart. Iys justTdept
maybee i kust
Please help!
Thanks, dom
Old Sep 10, 2012 | 05:08 AM
scottiemann's Avatar
did you double check the piston was still at TDC and aligned the cam gears per honda spec?
did you clamp down the intake boots and double check all the hoses?
are you running manual CCTs in which case did you adjust them correctly?
did you check valve shim backlash or just put the shims back in the same place?
the loudness may just be that it needs a few miles to break in however you may also need to sync your carbs
Old Sep 10, 2012 | 09:11 AM
Stock ccts, Yes the piston was still at tdc the bike was on a stand the whole time and i put it at tdc before i tore it down. I did check the valve lash and had to adjust the shims to get the tolerances to .006 +\- 1 for intake and.012 +\- 1 for exaust. Double checking the hoses an intake clamps is what im doing today, then synchronize carbs. It will still pull the front wheel off the ground but seems to be lacking when accelerating from 3k rpms up while crusing in 5th gear at 60mph. I could just be tripping, this was the first time i have tore into it that far.
Old Sep 10, 2012 | 02:01 PM
So apparently i put the stacks above the carbs in the aircleaner box in the wrong spots. I had the short one above the rear carb and the tall one above the front carb. Now hopefully tuning the carbs will get rid of the lurching when cruising at 25 mph or lower.
Old Sep 10, 2012 | 02:11 PM
saige's Avatar
the boss
hmmmmmm,i would think it still would run good even if switched,maybe not perfect,but dam near it.
Old Sep 10, 2012 | 03:35 PM
Well he did say it ran good but just with a small flat spot... but then again I ride 60 in 3rd or 4th not 5th and like to keep my SH in the mid to upper rpm band..
Good catch on the stacks and putting them back to normal and a Carb sync should even you out
Old Sep 10, 2012 | 05:29 PM
When im crusing along at 5k rpm you can hear me coming from 5 blocks away. It has a set of D&D slipons on it but they are hollow.
Old Sep 10, 2012 | 06:44 PM
Almost like running chambered mufflers on a v8 with no tail pipes...
Loud pipes save lives
Old Sep 10, 2012 | 07:22 PM
More like a v8 running just headers. And even louder now.i found an exhaust leak where the rear pipe from the head connects to the rest of the exhaust.
amazin
Feb 15, 2011 04:01 PM
malahhaor
Jun 21, 2010 05:27 AM
cscrawford
Jul 26, 2009 10:26 PM
quakefiend420
May 19, 2007 12:44 AM
