Slow turn signal fix.... the obvious method
Old Mar 6, 2015 | 07:36 PM
CentralCoaster's Avatar
I know this is a common issue but I've been dicking with it for awhile, cleaning bulb sockets, cleaning the switch multiple times, using bulb grease everywhere, probing the harness and relay...
I finally bought a new Honda switch. it's the whole shebang that mounts to the bar plus harness. Done. Instant signals. Pretty easy to install and surprised that it was only $70ish at Ron Ayers. I wasted a lot of time because I assumed the switch would be crazy expensive.
After cleaning the switch thoroughly I could get it working pretty well for the first few days, then it'd go to being even worse than before. Literally taking up to 5 minutes to start blinking every time even in warmer weather. I hated commuting without signals.
My conclusion is that the contacts were worn to the point where they either don't make enough contact, and/or the coating (if any) is worn off and the base metal that's left corrodes quickly. No amount of cleaning and lubing would cure it. I scraped with a wood toothpick to try and get a cleaner surface. Also it's about impossible to get at the middle of the 3 contacts.
Old Mar 6, 2015 | 07:46 PM
Hmm. I found that dismantling and cleaning with contact cleaner made it work like new all winter.
It helps to use a contact cleaner "pen" (has abrasive strands in a pen form). Makes it like new.
Like this http://www.amazon.com/Contact-Cleane.../dp/B00006IVJJ
or this Pro Motorcar 3437 PrepPen Adjustable Sanding Pen
Didnt know I couldnt live without them til I had em. Works on any metalic contacts (bulb bases etc)
vtrwillie72
Mar 15, 2012 11:55 AM
wshski
May 19, 2010 07:49 AM
killer5280
Oct 13, 2009 07:15 PM
ruf455
Oct 31, 2007 07:43 PM
sux9000
Oct 21, 2007 07:26 PM
