Showa OEM shock rebuild
Old May 27, 2009 | 06:26 PM
  #91
JamieDaugherty's Avatar
Ok guys, finally I was able to put together my prototype shock enough to get a few pictures of it. What is shown is just the replacement for the CBR's lower clevis. The adjustable part would thread into the bottom.
Replacement lower clevis parts. The red **** is now the rebound adjustment
With lower spring perch installed
Old May 29, 2009 | 09:38 PM
  #92
nath981's Avatar
jamie, i have an OEM shock I took off a my '88' 1000cc hurricane before I sold it. Are you familiar with it and if so, would it be useful to mod my superhawk shock or could it be modded to fit?
what is this latest shock you have pics of above?
Old May 30, 2009 | 05:43 AM
  #93
Now, that is pretty... I'd sell my soul for that...
Old May 30, 2009 | 08:25 AM
  #94
No, you won't want to use that shock. Your stock VTR shock is better!
The shock shown is from a CBR600F4.
Old May 30, 2009 | 06:59 PM
  #95
nath981's Avatar
I thought because it had a remote adjuster that parts could be used. So what are you doing with the F4I shock, making a poor man's ohlins for us?
Old May 30, 2009 | 07:12 PM
  #96
You can pretty much think of it that way. For the street I think you'd be hard pressed to notice much of a difference. I've ridden Ohlins rear shocks on the street and track and I can say that a for me a Showa with RaceTech internals performs just as well.
I'm hoping to get the adjustable ride height worked in as part of the conversion, that will really add some icing to the cake!
Old May 31, 2009 | 06:40 AM
  #97
nath981's Avatar
I put an Ohlins on that 88 cbr 1000 hurricane along with a 5.5 rear wheel and race tech front and that bike rocked except for the 600lb weight. Since I upgraded the Hawk's front end and raised the rear, the overall suspension feels less balanced and planted and the rear shock feels like it doesn't have enough length to work properly, Feels like it fully extended or hits the stops over bumps and fast humps. I'm going to up the compression adjustment today and see if that helps, but I know it's a poor performing shock by overall feel.
Old Jun 1, 2009 | 08:49 AM
  #98
So Jamie, are we at that majic point where I can send you an F4 shock & pay you to ship me back the conversion? Is the F4i shock the same?
Old Jun 1, 2009 | 09:16 AM
  #99
Oh boy, we are past that point - this has been a go for about four months now. I've been sending out converted CBR shocks to fit the VTR pretty regularly. In fact, I can convert other shocks besides the F4, I'm working on a CBR600F3 for a forum member right now in fact. The F4's are a good choice because they offer good performance and quality and can be purchased cheaply on eBay.
Yes, the F4 and F4i shocks are identical. Don't get hung up on spring color either, Honda put a red or yellow spring on there only to match the bodywork color - the springs rates are the same.
Old Jun 1, 2009 | 09:30 AM
  #100
Stevebis1's Avatar
I think maybe the "magic point" refered to the F4i conversion that includes the adjustable ride height.
Sounds like we (you) are almost there?
Old Jun 1, 2009 | 09:31 AM
  #101
OK, so I send you an f4 shock & what are the conversion prices. You can email me @ englatona @netzero.net. I believe its one price to convert & another for race tech. This is only for the street so I may not need RT. Thanks
Old Jun 1, 2009 | 09:37 AM
  #102
The adjustable ride height version has still got some work to do. The costs are too high right now, it would put the conversion over $200 without the cost of the spring. I'm still working and have some ideas, hopefully in the next month I'll have something. If anyone has an F4 shock to send over I'll be happy to make sure they are the first to get this done to it!
Old Jun 1, 2009 | 11:15 AM
  #103
HRCA#1's Avatar
Jamie, can you use 929/954 shocks for the VTR application?
Old Jun 1, 2009 | 11:30 AM
  #104
Possibly, I've not gotten to that point yet. I've got a WP on my bike that was originally for an R6. It has the reservoir mounted in a similar fashion to the 929's and 954's, so there is a chance that it would work. The actual modification would be a little different that what I've shown on this thread - the extension would have to be at the top and not the bottom. I do something similar to the 02+ VFR800's, the next shock I do like that I'll try to get some pictures and post them up.
Old Jun 1, 2009 | 12:05 PM
  #105
nath981's Avatar
jamie, just bought a 2005 f4 shock off ebay. Is it ok to send it direct to you from seller if i can get the info to him in time.
nathan
Old Jun 2, 2009 | 04:40 AM
  #106
nathan
I got your e-mails and will let you know when it arrives!
Old Jun 2, 2009 | 05:31 AM
  #107
nath981's Avatar
OK thnx
Old Jun 2, 2009 | 07:39 AM
  #108
reaper's Avatar
Just to chime in here, the revised F4i shock is a bit taller than the stock VTR shock. So for those that have shimmed there stock rear shock and plan on getting a modified shock from Jamie, might want to remove the shim when installing the new shock first, see how it rides and then add the necessary shims.
I did not measure the shocks side by side, but I can tell in the seat of the pants that my shock is a bit taller.
Old Jun 2, 2009 | 08:46 AM
  #109
My standard procedure is to add 6mm to the length during the conversion. I also have parts for +3mm as well. For no extra cost I can configure other lengths, it would just take an extra week or two.
Old Aug 6, 2009 | 04:36 AM
  #110
Well, mine isn't nearly as pretty as Jamie's... but here are some pictures of my DIY adjustable upper mount for the CBR shock... I had it off to paint it...
http://iloapp.tweety.se/gallery/images?Album&album=53
Old Aug 6, 2009 | 05:52 AM
  #111
Not bad, I think it looks pretty good in fact!
Old Aug 6, 2009 | 06:03 AM
  #112
Stumpy's Avatar
If you need stock vtr shocks for the mods I have 2 that I will give to anyone that pays for the shipping cleaning out the garage and I put a Ohlins on mine.
Old Aug 7, 2009 | 10:56 AM
  #113
stebbdt's Avatar
COBB Member
So let me ask both Jamie and Tweety this, If I get a F4i shock, have it "worked" by Jamie with a spring to match my weight, and, I don't want an adjustable option, all I'd need to machine up is basically an extended clevis? Similar to Tweety's version but instaed of adjustable, just thicker at the top to a set length. Correct?
Old Aug 7, 2009 | 11:01 AM
  #114
stebbdt's Avatar
COBB Member
Or is that the other part of your equation Jamie? I guess what I'm getten at is this.
I send ya an F4i shock, I want set length, new spring, "worked", no gold valve stuff? (or is the gold valve stuff part of the "worked" process). How much?
Thanks
Old Aug 7, 2009 | 11:13 AM
  #115
Moto Man's Avatar
Duc Hawk
Any progress on the adjustable option? Do you still need someone to send you a F4i shock for you to perfect the adjustable option with?
Old Aug 7, 2009 | 12:59 PM
  #116
Well, Jamie quoted above "set lenght" at X price, and that is with a fixed lenght extension (pics above in thread) that put's the shock at stock lenght for the hawk... Ie just bolt it on and go...
The reason I opted for a "custom" option is that since I was doing the swingarm swap the option to adjust rideheight was essential to me and I couldn't wait for the snassy CNC'ed adjustable one...
So I got mine without any extension as I needed the sapce to make it adjustable...
Old Aug 8, 2009 | 05:12 AM
  #117
Thanks
The Gold Valve is not part of the conversion process so therefore it's not necessary. If you wanted just the conversion and new spring the total would be $240.
It's real close, I'm just so slammed with other stuff that I've not gotten around to ordering the parts. I've already prototyped the design on a spare F4 shock so it's pretty much ready to go.
Not stock, I almost never make them the stock length. I typically add 6mm to the length unless instructed otherwise. I have parts for +1mm, +3mm and +6mm shock lengths over stock.
Old Aug 8, 2009 | 09:01 AM
  #118
Doh!... Sorry about that... I knew you was trixy...
Old Aug 8, 2009 | 07:36 PM
  #119
stebbdt's Avatar
COBB Member
Jamie, is there an option to buy a Kit so to speak, with a spring and conversion clevis,and of course intructions for installation, for those of us who have access to the proper machines, bridgeport, lathe,press. And a way to properly put a nitrogen charge to it.
Old Aug 9, 2009 | 12:46 PM
  #120
No, I don't do that. The reason is that I've been burned by that in the past. The person on the other end didn't do something just right and had problems - basically blaming it on me. This is in no way an indication of you or your abilities. I'm sorry that it has to be that way, but it is what it is.
