SuperHawk Forum
-   -   Running Rich? (https://www.superhawkforum.com/forums/technical-discussion-28/running-rich-22498/)
rackovanz May 13, 2010 09:34 AM
Running Rich?
Well,
I have searched on here and I have not been able to locate a similar issue. I have a mostly stock bike with the baffles removed, pair mod completed, the carbs were just synced. I bought the bike form SPDRCR a member on here. It is a 98 with 39000 miles on it.
As for the issues.
I have to use choke no matter how warm the bike is, and it takes forever to warm up. I am talking 5 miles at 80mph and get of on the exit and it dies. But 10mins later its fine. I only get high 20's mpg and it smells rich.
The TPS mod has not been completed, I took it to a local shop and they said to put a BMC in it to see if it will lean it out, it that right??? Also will a jet kit fix this or is that used just to richen a bike. I am at a loss and am running out of cash, my wife added it up I have spent 1500.00 in the last two weeks on it lol.
Could there be an issue with the carbs, like being dirty?
Any thoughts?
FL02SupaHawk996 May 13, 2010 10:08 AM
Sounds like the BMC or a K&N might help, but make sure you cut the air dam off the old filter and install it with the new one to help keep the turbulence down in the air box. I haven't re-jetted anything yet, but there are plenty of folks here who have and I think they'll tell you that re-jetting will likely fix the problem, but you may need a tuner with a dyno to get it done right....
lazn May 13, 2010 10:36 AM
If you have to use the choke to run, then it is lean and not rich. Pulling the choke knob enriches the mixture, not leans it out.
And running with the choke on will make it smell rich. My guess is that you have to clean the carbs. There is probably some gunk - varnish in there that is messing up the jetting.
If I were in your shoes I would run a few tanks with seafoam through there to see if that helps.
rackovanz May 13, 2010 10:51 AM
When it runs choke off it smell very rich. I will open her up and check the carbs.
Tweety May 13, 2010 10:59 AM
And a side note... Running the choke for to long might make you need a new engine... So keep that to a minimum...
residentg May 13, 2010 11:23 AM
Prior to the TPS adjustments my SH was impossible to start and ran poorly until warm. Now it starts right up and runs well, no rejetting yet, but that is in the plan.
rackovanz May 13, 2010 11:31 AM
OK I will do the TPS tonight! Thanks Tweety, I will keep it to a minimum!
rackovanz May 13, 2010 11:34 AM
Can the TPS correct it running rich, or at least make it appear that it is?
revhead1957 May 13, 2010 12:36 PM
Check the diaphragm in the fuel petcock. If it is busted, you will run lean and smell of petrol.
spdrcr May 13, 2010 12:55 PM
Done that
:iagree:
Check all the vacuum and fuel lines at the rear of the tank. Also check the caps / plugs in the lines that we used for the carb sync.
psyclown May 13, 2010 12:57 PM
how about setting the air/fuel mixture screws?
residentg May 13, 2010 02:15 PM
No, but it will remove a symptom that can be confused with incorrect jetting. Results seem to vary with the TPS adjustment. It made a very big difference for me, others it has not. Read the KB thread on this - it is excellent.
The PO for my bike put a jet kit in, I do not know what it is, but it is not bad, rich if anything. I have a Factory 1.1 kit on order since I cannot leave well enough alone. I will be better able to comment on jetting once I mess with that.
residentg May 13, 2010 02:18 PM
Originally Posted by rackovanz (Post 265685)
...I am at a loss and am running out of cash, my wife added it up I have spent 1500.00 in the last two weeks on it lol...Any thoughts?
Yes, do not add it all up with your wife, big mistake. Sorry I had to...
JB
rackovanz May 13, 2010 02:27 PM
Matt,
I will just wait till you have time to help me mess with it. I am off till Wednesday next week so whenever you have the time. I just don't want to mess it up more by fugging with stuff I don't know about.
Zachary
Thanks for everyone's suggestions I will keep you all updated.
