running on 1 cylinder.. .or so i assume
alright guys, im from mn and it is just starting to get into riding season we hit 48 today and i wanted to get out, got my new battery installed and fairings back on and new SS brake lines bled and i get real excited to start her up, fires up pretty well on choke and then starts to have an issue idling. drive the bike from the back yard/garage to the front of the house and there is NO power, bike wants to die when i pull the clutch in and when i get out front i let it idle for a little
get off go around back and feel exhaust, one is warm and seems normal and the other is almost cold air and smells like gas. i put my hands close to the header on the front cylinder and its warm i can tell without getting too close and then the rear header about 3 inches from the engine is BARELY warm, i could hold my hand on it without an issue... very traumatic experience as i take very good care of the bike and winterize properly and since 09 when i got it there has never been an issue any help or suggestions would be appreciated i just wanna ride :( |
Your probably right, no fire in the back can, Put some seafoam in and run it for a while, see if it opens up. You either have a clogged jet or aren't spark. My bets on the jet, probably didn't get all the fuel out last fall.
Originally Posted by spladle160
(Post 352141)
i always winterize the bike WITH stabil in it, never had a problem before but who knows im going to drain the tank and pull the carbs and do the carb setup to ensure i have it right. |
Gotta put gas in it... mmmmmhhmmmmm
ok so spark plug wire off on rear cylinder and spare plug in it, it sparks while grounded on the frame.
i have yet to take the carbs out as i wanted to make sure it was necessary first. does anyone have experience with using stabil and having running problems after storage? it was a pretty long winter for the SH this year.... im going to take the carbs off and see what they look like inside im going to read the how to on setting TPS and do that as well, also who has the haynes manual? had to re-read the direction that said "now torque bolts until head shears off...." made me laugh cheers all |
got the carbs out today and tore them down, i have NEVER taken carbs apart that were so clean! i was extremely impressed/disappointed....
happy they are clean and everything is as it should be but sad because that means something else is amiss with the bike, i dont really get what it could have been other than the gas was bad and fouled up the rear spark plug... im going to put it all back together, adjust TPS and see what happens.... other than that i dont know what could be wrong, i put it away in november and it was running flawlessly :mad: |
Dont let a sparking plug fool you. I've been a MC mechanic for 25 yrs and I have had plugs that would fire out of motor but not under compression. Actually had brand new ones do that to me a couple of times. Does the spark look blue & sharp or yellow & faint?
Originally Posted by SPRHK
(Post 352389)
the spark plug i was using was my spare i keep under the seat and it looked pretty yellow... i didnt have my extension to get the new ( last october) plug out and check that one, could it up a failing coil or if the spark isnt BRIGHT and blue just replace the plugs? |
The first & easiest thing to try is a plug swap. If the new plug also has a faint yellow spark, it could be a faulty coil.
(Post 352404)
Originally Posted by Bearshawk
(Post 352433)
hmmm i think this is a good time to swap to the CBR coil mod if they are bad :p
so i decided to start fresh with new plugs and new gas in the tank and synch the carbs... all is good HOWEVER
i got spark plugs from the dealer today, tousley motorsports here in MN and the plugs i got are in honda boxes and are NGK DPR9Evx-9's and are different than the other set i put in last september... i got them from a dealer as well but the ones i have in currently i know are iridium plugs not sure of the actual plug numbers.... are these what others are using? |
Original plugs are not available anymore. The Iridiums are what they replaced them with. They work well. Dont sweat it.
so after the saga of only running on once cylinder i finally got my little brown box from honda with the new pre-filters, and boost joint for the front carb synch point i added in and got it all put back together and added a gallon of 92 octane and PRESTO runs like a champ and holy crap... long mn winters i forget how hard she pulls :eek:
i am so excited for warmer weather...if it ever comes along |
Awesome! Glad all worked out well for you! Now go ride the wheels off that bike!
