Rubber fuel lines refresh
Old Feb 11, 2020 | 07:26 AM
bigborer's Avatar
bigborer is on a distinguished road
Hello,
I want to replace the petcock diaphragm and all rubber fuel lines.
Could someone tell me the ID and OD of the lines? It seems that there are plenty sizes of rubber "fuel safe" lines at car part stores.
Thanks!
Old Feb 11, 2020 | 10:23 AM
Originally Posted by bigborer
Hello,
Thanks!
Old Feb 11, 2020 | 01:20 PM
Wicky's Avatar
BULK HOSE PART NUMBER PATTERN
https://www.cmsnl.com/help/faq/14_honda/
Bolton Motorcycles - VTR1000F (FIRESTORM) 1997
The schema below should give a rough idea of the construction of fuel and vacuum hose part numbers. keywords: vacuum, bulk, hose
Careful using straight replacement fuel hose as there's some some tight kinks just after the petcock connection, this can crack after a while causing fuel leak. OEM fuel hose comes kinky :-)
Old Feb 11, 2020 | 02:57 PM
bigborer's Avatar
Thank you for the replies!
@E.Marquez - do those sizes work without the quick connectors? Quick connectors would be nice but I take the hoses off so rarely that it would not justify the added hassle
@Wicky- I will inspect the existing hosing, although I think some of them have no printed codes. My bike is from '01, so the petcock is behind the tank hinge, so maybe the radii aren't that tight. I'm not expecting to find any specs regarding the minimum radius of straight lines so I will only know after fitting them if it will be an issue or not. Thanks for pointing this out though- I didn't think about it but regardless of durability, kinking past a threshold will restrict the flow.
It doesn't seem like the brightest idea but... has anyone tried to induce a permanent radius in a straight hose using a heat gun + bending the hose to shape?
Old Feb 11, 2020 | 05:18 PM
Yes they do those hoses attache to everything normally attached to...they just have quick disconnects in the middle (give or take)
Rich Daniels
Feb 26, 2019 03:51 PM
Bobby Santos
Mar 11, 2018 04:06 PM
whatthefnck
Dec 3, 2017 07:04 AM
chadnol10
Jun 28, 2011 04:18 PM
AKBadRep
May 31, 2011 11:14 AM
