rear shock spring rate
Old Jan 17, 2010 | 07:30 AM
jason54's Avatar
jason54 is on a distinguished road
hi everyone
new to form what great info you guys have
the stock shock so the book says is sprung for 180lb rider
does anyone know what this translates to in spring rate
looking at buying an aftermarket shock on ebay and it says
the rear spring is 900lbs and I have no idea what this means
in rider weight.
also I added pic of my hawk to profile when I post it dosnt show it under my name like others do
Old Jan 17, 2010 | 07:58 AM
NH-Raptor's Avatar
jason54
racetech.com
put in bike type year etc
Put in street or track and your weight and it will spit out what spring rates you'll need. Make your choice and send in money.
Old Jan 17, 2010 | 08:49 AM
trinc's Avatar
the spring rate is based on bike+rider+gear+riding style.
i have a 1k spring @ 180 lbs give or take and set aggressive ( track )
the preload adjuster is in the upper range so my guess a 900lb spring would be good for around 150 lbs rider.
tim
Old Jan 17, 2010 | 12:35 PM
jason54's Avatar
I went to race tech web site and they dont even list the vtr1000 in
thier list of bikes. the shock im looking at is on ebay and its a fox racing
shock. The stock emoltion single adjust shock on my bike leaked the
fluid out while the bike sat on my lift for some time and I wanted to upgrade so I bought a rc51 rear shock for the double adjustablity
and with the proper provisions made it fit the bike but the spring rate
was about half enough for that bike so after you respring it and revalve
it you are not far from spending enough to buy used after market.
Old Jan 17, 2010 | 12:46 PM
thefitzvh's Avatar
thefitzvh is on a distinguished road
that's weird. i found it... go to search, spring rate search and select what you need. It's listed under street, then honda, then VTR1000F
http://old.racetech.com/evalving/Spr...ork&bikeid=267
go there. put in your info and go for it
Old Jan 17, 2010 | 01:17 PM
stebbdt's Avatar
COBB Member
Also do a search for F4i shock mod, to see what JD can%
Old Jan 17, 2010 | 01:27 PM
Ya, the race tech "find what we have for your bike" works great.. (it is a VTR1000F in case you wondered)
and according to them the stock rear shock spring rate is: 16.4 kg/mm
Old Jan 17, 2010 | 05:16 PM
JamieDaugherty's Avatar
The stock shock spring is indeed a 16.4kg/mm (918lb/in). I calculate that as being good for a 161 pound rider. Here is a table that I've put together that might help you with spring rate selection:
Rider = Spring Rate
95-130lb = 850lb/in
130-165lb = 900lb/in
165-200lb = 950lb/in
200-240lb = 1000lb/in
240-275lb = 1050lb/in
If you want the Metric rate just divide the lb/in value by 56 and that will give you kg/mm.
I hope this helps!
Old Jan 17, 2010 | 08:08 PM
jason54's Avatar
thanks everyone you guys are great info
how do I get it to show the pic of my bike under my screen name like everybody else?
Old Jan 18, 2010 | 11:26 AM
bjorn toulouse's Avatar
Destructive Tester
Click on "User CP" then "Edit Avatar".
Rex
Old Jan 19, 2010 | 04:44 PM
jason54's Avatar
yes
I painted it and did the airbrushing my father and I have
a shop in atl area we do custom paint and airbrush as well as
sport chopper conversions
roncris
Apr 1, 2012 09:03 AM
smokinjoe73
Mar 22, 2010 08:31 PM
RuthlessButcher
Jul 7, 2009 04:08 PM
speedkelly@aol.com
Jul 18, 2007 06:00 PM
roadrun_fr
Jul 20, 2005 02:37 PM
