Rad cap replacement
Rad cap replacement
Some time ago I posted up a list of rad caps that would fit the vtr.
Can anyone help me find that list. I am having issues and need a new cap before I ride to work so kinda important.
radiator cap cross reference An alternate to oem is Stant #10233 available at Advance Auto for 7.49. 1.1 bar=16lb. I found my gasket was split on the original cap while I was changing coolant. I also found my overflow bottle was plugged. I unhooked the overflow hose to drain the bottle and nothing came out. I used my compressor to clear the blockage while flushing the bottle with a hose and let the sediment float out.Just wanted to share this because the overflow function probably rarely gets tested.
