R/r blocking voltage from stator?
Old Sep 10, 2009 | 04:12 PM
Montana's Avatar
Montana is on a distinguished road
When I check the a/c voltage from the stator at the rr it is less than 10 v. If i unplug the rr and then check the voltage from the stator is great. 20+ voits and more as i increase rpm. Can a bad rr kind of block the reading from the stator ? RR Is than year but is cheap one from dennis kirk.
Old Sep 10, 2009 | 07:45 PM
Yes a bad R/R will cause all kinds of weirdness.
The only place that has lifetime warranty R/Rs is http://www.motovoltage.com
They also show how to test your stator, if it passes this test, your stator is fine:
http://www.tiny-media.org/motovoltage/tech.htm
Old Sep 10, 2009 | 07:57 PM
Make sure you check the connections under your seat close to the tank. If these corrode they can cause a problem. I just had to fix mine.
Old Sep 11, 2009 | 05:05 AM
Erik S.'s Avatar
My Motovoltage R/R should be here today. It will plug in to the connector right at the tank, and connect directly to the battery. Russ (CircuitBurner) has been great on the phone and has plenty of knowledge to share, plus other stories.
If you listen to him, he'll tell you that R/Rs are like tires, they will eventually wear out. His comes with fans, and seperates the Regulators from the Rectifiers so that they do not share heat.
The best benefit of buying from Russ, you support a member of OUR community (and you can take it off the SH if you ever sell it and put it on your next bike).
dshakes
Apr 16, 2009 04:24 PM
mcbrien
Jan 16, 2008 08:08 AM
wormeater
Nov 19, 2006 10:52 AM
wormeater
Nov 12, 2006 06:01 PM
mikecronis
Nov 27, 2005 06:50 PM
