Question about Genmar handlebar risers
Old Jun 27, 2010 | 09:34 AM
superh1998's Avatar
I just installed the Genmar handlebar risers, and I think everything is OK, but before I torque everything down, I wanted to run a few things past you guys.
I raised the fork tubes 4mm (from what I have read, that is acceptable).
With the risers installed, the clip on has 10mm that is not clamping to the fork.
I know that there has to be a little room for the sleeve that holds the cap that covers the preload adjuster, but is 10mm too much not to be holding on to anything, given that the clip on is 33mm?
I have attached a couple of pictures so you can see what I am talking about..one is with the sleeves for the caps, and one is without.Question about Genmar handlebar risers-2010-06-27-11.29.21.jpg
Old Jun 27, 2010 | 11:51 AM
superh1998's Avatar
OK, I think I solved the problem.
I forgot to mention that I had Jamie do my fork springs, and gold valve...so I raised the fork tubes to 9.5mm over the original height.
That only left about 4mm of the clip on that is NOT clamped around the fork.
I think this will be better.Question about Genmar handlebar risers-2010-06-27-13.11.25.jpg
Old Jun 27, 2010 | 12:58 PM
superh1998's Avatar
Just went for a ride...I personally don't like the feel of the bike with the forks moved up in the trees, and I don't see how these risers can be used safely unless you raise the forks, so I am going back to stock.
I guess you will never know unless you try.
Old Jun 28, 2010 | 02:48 PM
viperkillertt's Avatar
Josh
viperkillertt
Thanks for the info.
Old Jul 11, 2010 | 08:04 PM
majordomo490's Avatar
majordomo490 is on a distinguished road
I have gen mars on two of my bikes and have no problems. There is enough of a clamp to hold it securely.
Old Nov 9, 2010 | 02:35 PM
intoxxx's Avatar
haha yeah
intoxxx is on a distinguished road
pics?
mhaisten
Nov 29, 2009 12:12 PM
mhutch
Jun 30, 2007 08:14 AM
VTwin996Rider
Nov 2, 2006 04:41 PM
CNI Dawg
Jun 6, 2006 04:28 PM
superbling
May 17, 2006 09:17 AM
