question about engine noise
Thanks for all the advise you guys have given me. Ive got a new question. So I havent really ridden this bike yet, still going over everything. So when I start her up she sounds great nice and smooth. After she gets warm, and I give it a little rev I get what sounds like a clicking sound toward the front of the bike. I dont know ANYTHING about bikes but if it were a car I would say a lifter sound...How do I check the oil level? When I start it the sight glass empties and then when warm it fills back up? Any thoughts?
check your oil level when cold with the bike in level riding position.
if it sounds like a bunch of ball bearings in a can,it may be tensioner.
our bike does make a bit of noise though. |
No its more of a clicking.
can you post a video?
Might be
Might be the valves. Earlier last month I took my bike to the Ducati dealer for a preseason inspection and asked about valve adjustment. The Ducati dealer said to me "clicking or loud taping noise consistence with the revving is a sign of the valves needing adjustment". I didn't need anything done but it was good peace of mind.
Damn I'm hoping its something simple..I dont want to dump $ into a bike with a rebuilt title I wont get back! I'll try and get a video up..
Engine noise
1 Attachment(s)
Tried to take a video but cant hear the noise over the Jardine pipes.. Noticed a few drips of antifreeze out of a drain tube while doing the vid...What is this? Temp was only 160? Pic.
Does it just do it at idle or throughout the rev range?
Without hearing it the noise could also be an exhaust leak or just the carb slides bouncing around. Also with .012" clearance on the exhaust valves, they can "tick" a bit also, Does it do it more when it is cold or when it is hot? To check the oil level the bike needs to be not running and should be between the lines on the sight glass. |
Only makes the noise over like 150 degrees? When its cold it sounds great. It stays thru all rpms...
We are are guessing here, take it to a dealer or get a experienced guy over. To prevent more damage stop running it. If lashing is needed that is not too expensive and can be done at home. If it's major I have a all stock running motor about to be up for grabs.
If it's only doing it when warm, it's very likely a loose valve (too much lash). But like 8541Hawk said, a slight exhaust leak can sound just like a loose valve.
With it running and warm, use a long bladed screwdriver (2' or so) to isolate the noise. Put the tip of the screwdriver blade on the valve cover. It acts like a stethoscope with your ear pressed to the end of the handle. |
Is a loose valve an expensive fix? I dont want to dump $ into this bike...
The terms "loose valves" and "tight valves" refer to valve adjustment. It would mean you need a valve adjustment. Having a loose valve is better than having a tight valve, which you would not hear. And a tight valve will cause the valve to burn.
If you don't have a somewhat high level of mechanical skills, shim type adjustment (which our bikes have) is best left to a qualified technician. But even if you take it to a shop, get some references first. There are a lot of hacks out there charging $50 to $85 an hour for lousy work. |
most places want $300-$500 for valve adjustments on the super. Cheapest method is to find someone nearby who know their hawk well and trade beer for help :D
1 Attachment(s)
leak at red circle?
if so water pumps seal. |
When was the last oil change? do you have mcc't? might be a leak from the combustion chamber to the water jacket. This could be the cause of leak, as for heaing a taping sound that is the puzzing part. or Bad water pump, before the bike get up to 160 the thero doesnt open putting more presure on the pump causing it to keeping quite. but once the presure is released the pump makes noise. these are all guesses. Your going to need someone to dig into it before it gets worst or drive it until whats making the noise flys out the side of your engine. JK, dont do that.
Originally Posted by Little_Horse
(Post 300485)
If you do it right, valve adjustment could be a 20-30 thous+ maintenance item, or it could be 5-10 thous if one or more is set at one under spec. Hope you can find someone in your area to help you. There are threads herein that can assist someone with a little mechanical ability. |
Originally Posted by lukenukem47
(Post 300493)
And the screwdriver method I mentioned above will help locate the source of the noise. It can be used on the water pump as well. Good thing our bikes don't have a dry clutch.:eek: |
(Post 300519)
Originally Posted by AngryOlaf
(Post 300528)
But that could mask most of the other quirky sounds coming out of our bikes, which would save so much stress and second-guessing! :D
Post your location to find out if someone nearby is willing to help you. |
I am in in Seattle/Renton Wa.
Originally Posted by nath981
(Post 300564)
eliminate a lot of the stress and second guessing by replacing or adjusting the CCTs, checking valve adjustment, TPS, and basic carb settings, filters, fluids, and plugs, RR, etc., so that you have a good idea of what you have and what you might be dealing with in the future. Not a good idea to just ride it and wait to find out what's gonna happen the hard way.
Coolant drip
1 Attachment(s)
Here is a pic of the hose that drips..It is literally only a few drips tho? Have been tracking down a battery drain also so I have started her a few times..She is dying when I put her into gear now????
yerp water pump seal is bad
Expensive?
Originally Posted by newbierider77
(Post 300592)
Expensive?
not sure on price of seals,labor is what usually gets you. save some labor by removing cover yourself and take to local shop. should be under 1 hour labor. |
(Post 300443)
(Post 300446)
So I've got an update..Putted my bike around today..Put about 3 miles on it, not wanting to cause any damage...The clicking noise went away?? came back a time or two but for the most part its gone...Does anyone think that it may have been caused by the shitty gas that was in her that was just burning out?? No weeping either..Any thoughts?
