Petcock operation
Old Aug 5, 2008 | 08:05 AM
Mark Morrison's Avatar
Mark Morrison is on a distinguished road
Petcock operation
I am new to the list. I have a 1998 VTR I am trying to get running. Looking for some help. The petcock appears to be a vacuum type with two positions:
  • Full on (like a prime mode)
  • Vacuum operated (supplies gas only when vacuum is created.)
Can anyone tell me if these are the correct modes of operation?
Also, there are two nipples on the pectcock that appear to be for vacuum lines. This there a difference in the function of each? If so, what.
Finally, my front cyclinder filled up completely with gas whiched leaked into the crankcase. Any idea on wheather this is a petcock issue or float needle?
Old Aug 5, 2008 | 08:13 AM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
See this link:
https://www.superhawkforum.com/forum...hlight=petcock
In a perfect world the needle would stop any fuel overflow into the cylinder. Having the petcock working correctly helps when the world is non-perfect.
Thumper's Avatar
The side nipple it the one you want to use, the lower nipple has no function.
Yes you have the petcock operation correct. Engine must be running for it to operate or flow fuel.
If you have fuel in the front cylinder then you may have multiple issues. The float may be sticking in the front carb letting fuel flow and you may have some type of petcock shut off issue.
Old Aug 5, 2008 | 04:21 PM
mboe794's Avatar
I had mine apart recently and I'm pretty sure the two modes are vacuum operated or completely off. I removed the diaphram and stopper inside due to a large hole in the diaphram and I can still shut it off with the **** on the front.
Old Aug 5, 2008 | 06:27 PM
Anto's Avatar
Anto is on a distinguished road
I have had problems with a sticking petcock -
I discovered the two modes are:
vac operated / on
and off
when I take my tank off, I manually switch the dial to off and it's fine.
Old Aug 5, 2008 | 06:43 PM
Thumper's Avatar
vac operated / on
and off
I do the exact same thing
Old Aug 15, 2008 | 01:52 PM
scarface's Avatar
asking a stupid question here, but where is the petcock on this bike?
Old Aug 15, 2008 | 02:01 PM
Springbubba's Avatar
Uhhhhh..huh.huh..Member..
It does not have your standard on/off/res petcock. It is vacuum on or twist off, and it is under the rear of the tank. You have to lift the tank to get to it.
Old Aug 15, 2008 | 02:04 PM
scarface's Avatar
ahhh...ok thanks. I was thinking to myself "oh crap, I never cut off my fuel!"
E.Marquez
May 20, 2013 07:30 PM
CrankenFine
Jul 7, 2011 06:18 PM
RK1
Aug 27, 2010 07:50 PM
superbling
Mar 26, 2007 11:19 PM
Radiaoktiv
Mar 23, 2007 03:25 PM
