SuperHawk Forum
-   -   PAIR System removal What could I have done wrong? (https://www.superhawkforum.com/forums/technical-discussion-28/pair-system-removal-what-could-i-have-done-wrong-24665/)
Fox Feb 5, 2011 11:37 AM
Hey guys...I just used the PAIR system removal instructions from the forum and as I expected it was an easy removal. I did everything like the instructions BUT after removal, the Hawk will not run in the upper RMPs. It will start and idle but will not take gas. Yes I turned the fuel on, reed keeper(s) were inverted correctly, all hose opening plugged...I just can't figure it out. I didn't touch the carbs and yes removed my rags from the openings.
Before I put this system back on can anyone think of what I could have done wrong OR is there a chance that my set-up needs the PAIR system?
Dyno Jet kit, K&N filter and Yosh slip ons. The bike ran great last weekend but just had the little pop that I wanted to do away with.
Thanks
Stevebis1 Feb 5, 2011 11:55 AM
Look at your petcock again. Is there a vacuum tube going to the nipple pointing straight down? If so thats wrong. Vacuum hose needs to go to the nipple you can't see - the one pointing to the back. The one pointing down is a vent. Strangle the gas flow when you inadvetently relocate it there.... PVLIR
zwoehr Feb 5, 2011 12:06 PM
+1 I think this is probably one the most common mistakes people make when they take their tanks off.
I actually bought my bike with the vacuum hooked up wrong to the petcock and it ran fine for over a thousand miles... Then it suddenly quit. Luckily I'd noticed it when I synched the carbs and read about it here so I pretty much knew exactly what the problem was.
Fox Feb 5, 2011 01:01 PM
BINGO....Thanks guys. That was it. She runs now. Should be 52 tomorrow here in Charlotte NC so I will have a chance to see if the popping is gone.
This forum rocks!
RWhisen Feb 5, 2011 05:29 PM
Another victim of PVLIR......
VTRsurfer Feb 5, 2011 07:25 PM
The good news is you'll only do that once...like me.
superchickencornermonster Feb 7, 2011 06:25 AM
haha
Don't feel too bad man, a lot of people have made that mistake. In fact, that's how I found this forum. I was searching for a solution to my issues after I did a valve adjustment. And I'm a MECHANIC! HAHAHA!
nekkid Feb 7, 2011 02:28 PM
It's more common than the heartbreak of psoriasis...
