no gauges????
no gauges????
i put in flush mount blinkers yesterday and i went for a cruise. nothing happened. but when i started it up this morning there was no speedo tach or digital trip meter, no nutral light or stand light. the only thing that works are the blinkers and highbeam light.??? can you help me wih my problem? i am two weeks new to the superhawk. thanks
check out this thread from a few days back - similar issue... hope this helps.
https://www.superhawkforum.com/forum...ead.php?t=5677
What ended up being my problem (RickB quoted my thread) was that on my Watsen's, the running light wire was left out, and the cap I used ended up not staying on. All it took was just the tiniest bit of that wire to ground out on some bit of metal and it blew the Meter/Tail/Ilum fuse. Fixed the wire, replaced the fuse, and no problems since.
