Low temp fan switch gremlins-HELP
So I bought on ebay & finally installed & put some miles on the low temp fan switch. I believe it comes on at 160 instead of 180. I does indeed never let the bike get over half way on the temp guage (dont have digital) But on the down side in city traffic the fan is ALWAYS on. I keep my battery on a trickle charger so have been OK but this concerns me.
SECOND ( where I need help ) since installing this switch, I have noticed that when I pull onto a highway or long bridge & sort of put the hammer down, the right turn signal comes on intermitantly. This seems bizarre to me. Does anyone have ANY ideas about this??? My belief is that all this fanning is causing problems. I would rather swap back than fry my wiring harness. Guys- I could use help here.........Thanks
I cut and modified the battery box to accept a larger battery, 12 ah, so parasitic drains such as a cooling fan isn't an issue, and with the engine running the fan drain is within the capacity of the charging system.
I wonder if the turn signal harness is chaffed or has a loose component within the switch. So, what are the vdc readings on the bike? Normal?
Intermittantly; the first couple times I would think that I forgot to turn it off but I can turn on the other signal while its happening. Once I am up to speed it goes away. Your diagnosis sounds right. I was also worried that it was the hier current draw when the ignition was reved hier. I plan to look for a short. My wiring harness is suspect anyway from some mechanical "incidents" encountered throughout the life of the steed.
inderocker
Apr 26, 2010 06:44 PM
