location of main air jets
hey everybody
Can anybody tell or show me the location of the main air jets. I know they are one of the little brass things that you see on the top of the carb, but which one? I appreciate your help, thanks |
1 Attachment(s)
Sounds like someone is installing a flow commander....
The air bleed is on top, If I remember correctly it is the center one of the three but it has been a long time since I've mess with them.... |
7moore7 are you sure that's not a fuel jet? the way I understood it is the ones on the air box side are the air jets. very nice pic though
not installing a fuel commander, the jet kit I bought requires drilling the main air jets. you(8541hawk) posted on the last thread I stared about this, that's how I know that they are one of the brass things you see when looking at the carb from the air box. But which one? is a main air jet the same as a air bleed? Thanks for your input guys |
Originally Posted by rich.m
(Post 314607)
not installing a fuel commander, the jet kit I bought requires drilling the main air jets. you(8541hawk) posted on the last thread I stared about this, that's how I know that they are one of the brass things you see when looking at the carb from the air box. But which one? is a main air jet the same as a air bleed? Thanks for your input guys Though, like the last thread, I wouldn't recommend drilling them out. If you really want to do it anyways, the easiest way to tell is look through or shine a small light through the emulsion tube (where the main jet screws in) and see which hole on top lights up. That would be the air bleed. |
cool man thanks for clearing that up for me.
It would be nice if they just screwed out so you could try different sizes without consequences but that would be to easy right? I'm still tempted to try it. Factory pro insists that it is not just for higher tuned engines but gives better tuning on all engines(but of course they would say that).Who knows maybe it's the secret to jetting this bike with an aftermarket filter. I'll pass on the info if I end up giving it a try |
They don't screw in but are a fairly light press fit.
So what you could do in take a pair of diagonal cutters and lightly grab the air bleed and lever it out ( this is how they are removed and the plugs installed for running a ram-air set up) Then you could have someone (if you don't have access to a lathe) turn up a couple blanks and drill different size holes in them to try different set ups. If it doesn't work, you could then reinstall the stock bleeds. |
(Post 314628)
It would be nice if they just screwed out so you could try different sizes without consequences but that would be to easy right? I'm still tempted to try it. Factory pro insists that it is not just for higher tuned engines but gives better tuning on all engines(but of course they would say that).Who knows maybe it's the secret to jetting this bike with an aftermarket filter. I'll pass on the info if I end up giving it a try The slip-ons barely changes the equation at all from stock... And that airfilter actually flows a lot less than both the K&N and the BMC Race airfilter... So essentially, tuning for that filter, I'd tune the bike like with a stock airfilter, and perhaps adjust the mixture screw a tad... It's not even remotely close to the K&N in how you tune the bike... BUT, it is infact more free flowing than stock... So opening up the air bleeds to a larger diameter in conjunction with that filter, isnt a great idea... Infact, the only word that comes to mind as a description, is "stupid"... The only result you will get with the jet kit you have mentioned on a bike that is apart from those two bolt-on mods completely stock, is doubled fuel consumption and a big hole in the powerband... Doesn't matter what the manufacturers says... It's a fact that is easily proven by physics & mathematics, and it can easily be verified by a dyno... You could try it... The dyno will prove me right... Or you could just believe us when we tell you... After all, we are trying to save you the hassle of putting it back to stock afterwards... There is no free lunch... More power = cost money... |
Well put! You won't get HUGE gains over the factory setup. True that a set of pipes and the wrong filter can cause problems. Then some creative jetting can get it to run better again.
Of the two dozen bikes I have owned the VTR is the most difficult for some reason. But once it runs properly it is like a dream bike. At least it is for me. Miguel |
| All times are GMT -7. The time now is 11:32 PM. |
