larger piston on the clutch master cylinder
Old Sep 9, 2010 | 01:10 AM
skycam's Avatar
Mad Max NO Squid!
skycam is on a distinguished road
i would like to decrease the throw necessary to disengage the clutch.
would there be any negative effects to using an oversize clutch master cylinder? too much fluid? too much travel?
maybe this is a bit eccentric but i think it would be somewhat convent and quicker to shift.
has any one tried it?
Old Sep 9, 2010 | 06:15 AM
Seroiusly if the clutch is bled as it should and working fine it engages/disenagages at the outer point of the handle ie very short actual throw needed... Infact the most common question is "how to increase the throw"...
Either you and me are talking about the same thing using upside down terminology, or something is wrong with your clutch...
Increasing the size of the clutch master makes the fluid increase for the movement, ie even shorter movement... considering how short the stock is when working properly I doubt that's a good idea...
I'd suggest you start by re-bleeding your clutch... First to check is the banjobolt on the master (lots, lots of rags around to keep spills of the paint...)
Old Sep 9, 2010 | 07:17 PM
spladle160's Avatar
I'm with tweety, mine is fully disengaged (no power to wheel) at less than 2 cm from full out. If bleeding doesn't do it, and I'm pretty sure it will if done right, then you might try rebuilding your master cylinder. Put in new rubber and hone and polish the bore slightly.
Old Sep 9, 2010 | 10:08 PM
skycam's Avatar
Mad Max NO Squid!
my clutch works
my clutch works!
i just think it is excessive travel to get it fully disengaged.
just bled it yesterday
i think there is a risk of over extending the piston.
i guess i as curious if it was safe to do.
no big deal
i would like to reduce the lever throw to fully disengage.
Old Sep 10, 2010 | 02:22 AM
Well, then... HOW long is the actual travel to fully disengaged?
Old Sep 10, 2010 | 09:13 AM
Karbon's Avatar
Karbon is on a distinguished road
You might benefit from aftermarket levers that have greater span of adjustment.
Old Sep 10, 2010 | 09:58 AM
Stevebis1's Avatar
As others have said if your clutch is working correctly "fully" disengaged happens damn fast. Are you confusing the full throw of the lever with Fully disengaged?
Old Sep 10, 2010 | 12:31 PM
spladle160's Avatar
Just noticed your in Hawaii, it's pretty humid there right? Brake fluid is hygroscopic, you should use a new bottle everytime and avoid humid days to even open the reservoir if you can. If you were getting the full mechanical advantage the system has the clutch would disengage in a very short distance. Since it's not that means either there is a leak somewhere, flex in the line, compression of the fluid. The most likely cause is fluid (air and water being fluids) compression. Bleed it properly ride it for a week and bleed it again. It could also be a leak or the master cylinders tiny holes to the resevoir could be clogged.
Old Sep 10, 2010 | 03:35 PM
skycam's Avatar
Mad Max NO Squid!
good stuff i will apply all suggestions and get back
thanks again it may be i need better levers new fluid.
JayBird217
May 27, 2008 05:05 PM
Darrell400ex
Feb 17, 2008 06:42 PM
nineighthawk
Apr 26, 2007 10:04 PM
CNI Dawg
Mar 19, 2007 02:57 PM
superbling
May 21, 2006 08:25 PM
