Jetting problems- help!
Old Dec 22, 2004 | 03:47 AM
Random's Avatar
Random
Re: Jetting problems- help!
I know it sound stupid, but did you verify that the choke Lever works properly? (on both carbs?)
It sure sounds like the fuel enrichment for cold start isn't working.
Old Dec 22, 2004 | 09:12 AM
Alic's Avatar
Alic
I had the same cold start issue after slip-ons, K&N, Jet Kit and dyno jetting. The choke cable was only opening one of the carbs - for the other carb it broke off and keeps it shut. I ended up increasing idling RPMs via idle adjust screw (to 1400 RPM). When I start, I open choke momentarily, then start, crank the throttle and hold it there at 3k RPM for 30 secs (after closing choke). Then I blip the throttle a few times to about 8k, then let it idle, then blip it again a few times. When the temperature reaches 100F, I let it idle and heat up to 120F (which virtually eliminates the clunk-die thing, esp. while braking at traffic lights). Then I ride.
Adjusting the idle screw did make the bike run hotter in stop-go traffic. It is now running at about 200F.
I haven't attempted the TPS mod fix yet (no time), but will try it when weather gets warmer.
Old Dec 23, 2004 | 01:13 PM
JoeRider677's Avatar
JoeRider677
Chocke it actually an enricher! kinda important... Remember the LESS turns out from seated with the mixture (air bleed) the richer and cooler running around idle speed .... we hope. Damned things run HOT
Old Dec 24, 2004 | 07:05 AM
Rollingalong's Avatar
Rollingalong
Originally Posted by gwade";p=&quot
Thanks, I will check that. Note that it's also a bitch to hot start...also, I went into my garage last night and the whole place smelled of petrol. Never smelled that strong before...what might cause that? Perhaps something is causing the thing to flood when switched off?
Could be some dirt sticking the needle and seat "s" or the float height got whacked when the carbs were apart . Might want to check to see if fuel has got into the oil which is common when problems similar to this arise . Fuel will whack the viscosity index improvers and thin the oil out + a few more off topic problems like elevated cylinder wear ect .
A tip when restarting after the fuel bowls have been drained is to use an old gear oil bottle and prefill the bowls right through the main fuel line . Saves the starter and is a bit easier on the cams that get no appreciable lube while cranking .
coba
Dec 24, 2009 12:21 PM
Pimpsterbim1
Feb 16, 2009 01:52 PM
Anto
Nov 14, 2007 04:10 AM
macworld
Mar 3, 2007 09:43 AM
2000superhawk
Nov 17, 2006 07:49 PM
