Issues with my 1998 Superhawk not accelerating while in gear
Old May 20, 2024 | 04:54 PM
JParis90's Avatar
JParis90 is on a distinguished road
Angry Issues with my 1998 Superhawk not accelerating while in gear
So I have a 1998 Superhawk I inherited from my dad when he passed away. It had a couple issues I addressed (stator, rectifier, and battery). But, while riding on two separate occasions, I was riding and all of a sudden the bike wouldn't accelerate while twisting the throttle and in gear. Today I took off in first gear and it seemed like it was jumping and hesitating. I shifted to second gear and all it would do is rev with no acceleration. I am not sure what it could be. Please help.
Old May 20, 2024 | 09:31 PM
killer5280's Avatar
Slipping clutch?
Old May 22, 2024 | 11:43 AM
fabiostar's Avatar
going by your last line the clutch plates are goosed, try bleeding it and if that doesnt help you need new plates.
Old May 22, 2024 | 11:57 AM
JParis90's Avatar
Thank you. I'll get it to a shop.
Old May 22, 2024 | 12:01 PM
JParis90's Avatar
Fabiostar, I bled the slave cylinder again, even though the clutch lever had pressure on it. As I tried to bleed it, the bleeder valve on the slave cylinder as if it did not want to bleed the fluid. I had to loosen the bolt for the hose connection at the master cylinder and the back of the slave cylinder. I finally got fluid down to the bleeder valve. I rode the bike for an hour and no issue occurred. With the slave cylinder not bleeding easily, could I possibly need a new slave cylinder or master cylinder?
Old May 24, 2024 | 12:15 PM
fabiostar's Avatar
might not do any harm to buy a rebuild kit they are cheap. the clutches on these bikes can be a pain to bleed at the best of times, i always end up reverse bleeding them from the bottom, seems to work much better.
Old Jun 2, 2024 | 06:37 AM
You need to remove that slave and thoroughly clean it, and the master cylinder. They get a nasty gel type goop if not routinely bled. I posted pics on here many moons ago. I'll see if I can find them.
Old Jun 2, 2024 | 06:43 AM
Here ya go, click the link and scroll down to look at pics. Probably what you have going on.
https://www.superhawkforum.com/forum...h-issue-35686/
Old Jun 7, 2024 | 07:50 PM
JParis90's Avatar
Wolverine, thank you for that information
uchi
Nov 14, 2022 04:49 PM
Tormoz
Jan 24, 2012 11:53 AM
motormouth
Mar 21, 2010 09:46 PM
j shizzy wizzy
Dec 27, 2009 07:11 AM
cliby
May 11, 2007 02:48 PM
