Instrument cluster bulbs?
Old Jul 5, 2008 | 04:01 PM
CentralCoaster's Avatar
My temp guage isn't lit, and the bottom half of the tach doesn't show up well at night.
So I'm guessing there's 3 bulbs in there and one is burned out.
Do I just pull the 3 bolts off and pull the cluster out? Is there some exotic light bulb in there that I won't find at the parts store?
I'm gonna mess with it now, whats the worst that can happen?
Old Jul 5, 2008 | 04:12 PM
Ok, good news is that's easy, remove 3 10mm bolts, spin the cluster around, and the bulbs just pull out of the back of the cluster. Nice of them to leave enough harness to work with, gotta love Japanese engineering.
Bad news is it has 1.7w bulbs in there, and I know the parts store doesn't carry them.
Does anyone know the bulb # for these so I can search for em? I did a quick search through the archives and didn't find anything.
Old Jul 5, 2008 | 04:42 PM
SuperMike's Avatar
SuperMike is on a distinguished road
Good question. My temp guage is doing the same thing. My RR is on its way out and i had a couple of bulbs go out with it. I hope someone knows the bulb size.
Old Jul 5, 2008 | 05:09 PM
zmaniv's Avatar
A while ago I saw a guy that made bases with LED's to replace standard bulbs.
LED's use less power and will last a lot longer.
Old Jul 5, 2008 | 05:22 PM
Anto's Avatar
Anto is on a distinguished road
i think some of the bulbs are 168/194, i was looking into it a bit ago. most others are #74 i think? not 100% sure. look on superbrightleds.com, get wide angle leds.
Old Jul 5, 2008 | 05:27 PM
Mark S's Avatar
Mark S is on a distinguished road
Mine has 194's in it, cheap and available in most any parts store.
Mark S
Old Jul 7, 2008 | 06:17 PM
Hmm. The 194s are rated at something like 5 watts, about 3x the stock bulb, so I don't think that's it.
The smallest wattage I could find is a 161 bulb. It's 2.7W and readily available. I'll balance out the guage lights with 1.7s and put this 2.7 in the neutral light or something. Never hurts to have brighter light there.
Old Jul 21, 2008 | 09:55 AM
nwellinghoff's Avatar
nwellinghoff is on a distinguished road
Did that end up working out? The light behind my speedo just went out...I should probably know how fast I'm going at night...
Old Jul 21, 2008 | 10:45 AM
Yes, the 161 bulb works fine. Doesn't look any brighter than the others, but I put in the warning light anyways just to be safe and keep the guage bulbs all the same. Use a rag or something to avoid getting oil from your fingers on the bulb.
meanhawk98
Mar 22, 2012 02:31 PM
vtrwillie72
May 11, 2011 05:46 PM
Generation450X
May 25, 2009 07:14 AM
reaper
Aug 26, 2007 07:56 PM
roisman
Feb 9, 2007 12:27 PM
