ignition (key) problem.
Old Oct 9, 2009 | 10:40 AM
So riding in to work today, I stopped for a fill up. And as I went to leave, my key would no longer turn the ignition.. Felt like the wrong key, simply would not turn.
Spent about 3 min fiddling, removing, reinserting etc, till finally it turned.
So I rode home and grabbed the car.
When I get home I will spray some WD or similar lube in there to see if that helps.
Oh the joys of older bikes
Old Oct 9, 2009 | 12:28 PM
orangezuk's Avatar
orangezuk is on a distinguished road
Noooooooooooooooooooooo WD-40! Sorry just had to stop ya. Make sure you use a proper "lock" graphite/lube. WD-40 or simalar oils will work for a short time then just gum up and collect more nasties to screw up that ignition further.
Old Oct 9, 2009 | 12:53 PM
Check that the key is flat... I have once made mine slightly twisted due to not pushing the filler lid enough, and had similar problems...
Old Oct 9, 2009 | 12:54 PM
Key is flat.
I have some Gun oil, and some lithium based spray.. Would either of those work? Or do I need to track down some graphite stuff?
Old Oct 9, 2009 | 12:57 PM
orangezuk's Avatar
I'd stay with the lock specific dry lube, ie. graphite type lock lube. Thats what it's made for.
Old Oct 11, 2009 | 12:06 AM
Just to let everyone know.. some graphite worked great.
josiahbattaglia
May 28, 2010 01:00 PM
Westahooffen
Jul 29, 2007 06:39 PM
Motophoria
May 19, 2007 05:08 AM
phillip
Jan 30, 2007 02:11 PM
mamisano
Apr 3, 2005 12:41 AM
