If changing sprocket ratio do i need to change the chain?
Old Aug 17, 2009 | 01:25 PM
Red_Liner740's Avatar
Well, in particularly, the people who did the -1 +2 sprocte swap...did you have to get a new chain? is the stock one long enough to fit on there because of -1 in the front?
i have a fairly new chain and i wanted to play with the sprocket swap but its not feasible to get another chain when this one is fine...
thanks!
Old Aug 17, 2009 | 01:36 PM
PUSHrod's Avatar
New chain is not needed if the sprockets are pitched the same size as the old chain. One down in front and two up in the rear makes the S'hawk a wheelie monster, stoplight blaster and gas milage ogre. Have fun.
Old Aug 17, 2009 | 02:08 PM
RK1's Avatar
RK1
Increasing sprocket size means you'll use up more chain. Decreasing sprocket size means using up less chain. I know the OEM 102 link chain works OK with -1 front/+2 rear. Also OK with just adding a +2 rear. After that I'm not sure.
Old Aug 17, 2009 | 03:04 PM
^^ Thats all i wanted to know....whether a -1 +2 sprockets (15-43) works with stock lenght chain.
Old Aug 17, 2009 | 03:12 PM
RK1's Avatar
RK1
Yeah. You're good to go with the chain you've got.
Old Aug 18, 2009 | 05:51 PM
shayne's Avatar
Keep in mind this will shorten your wheelbase. Having a longer chain will allow you to keep it closer to standard.
Little_Horse
Feb 14, 2012 03:32 PM
alientestsubject
May 18, 2010 03:48 PM
joshuatest
Apr 6, 2008 09:18 AM
duran
Aug 27, 2007 07:57 AM
NOrrTH
Nov 25, 2005 09:59 AM
