Idle down pause.
Old Aug 27, 2021 | 03:52 PM
Bald Eagle's Avatar
Bald Eagle is on a distinguished road
Idle down pause.
Hey People out there
... I have a carb issue that I know someone could advise me on.
I have modifications on the bike as you know (Stage 2 Cams, 11:1 pistons and minor carb adjustments.)
When the Idle comes down after you bleep the throttle...there is a small pause/delay at the end of the revs before it rests at normal Idle.
Is it because that the Main Jets are too heavy (180 front 185 Rear) and the fuel is still in the carbs?
Does the TPS need to be set at a different resistance than 550 ohms?
Would appreciate any thoughts out there.
Thanks.
Old Aug 28, 2021 | 05:30 AM
How many turns out on the fuel screws? You might need to go up a size on the pilot jets.
Old Aug 28, 2021 | 03:53 PM
YMRacing's Avatar
Valves too tight will cause "idle hang"....
Old Aug 28, 2021 | 05:20 PM
Bald Eagle's Avatar
These are my Carb setupMain Jets Front 180
Rear 185
Needle Shims
Front .044
Rear .047
Pilot Jets 48
Air/ Mix Screw Front 2 ¼
Rear 2 ½
I had the Carbs Balanced on the vacuum ....but I will check that again. Never considered the valves too tight. I'll have to check that.
Old Aug 28, 2021 | 05:28 PM
Bald Eagle's Avatar
I do have Yoshimura stage II cams.
what is the correct valve clearance for stage II cams? I know they are greater than stock.....I think.
apezman07
Feb 23, 2020 03:31 PM
eersfanpilot
May 7, 2012 02:12 PM
scuzmuz
Jun 3, 2011 09:17 AM
Fish
Apr 2, 2010 05:50 AM
roadrun_fr
Aug 30, 2005 09:49 AM
