View Poll Results: How often U change oil?
1000 to 2000
26
13.83%
2000 to 3000
76
40.43%
3000 to 4000
62
32.98%
Over 4k
24
12.77%
Voters: 188. You may not vote on this poll
How often do you - Change Oil?
Old Sep 3, 2008 | 05:52 PM
  #31
Zedicus's Avatar
Zedicus is on a distinguished road
Best dissertation on oil, especially 0 weight. Take the quiz.
http://www.ferrarichat.com/forum/sho...d.php?t=136052
ive read that and variations of it more times then i care to say. also oil shootouts and lab comparisons of an actual engine ran on diferent types of oil that had lab work done on the oil after different mileages. i stand by what i say but i will add one thing, the weight of oil you run needs to be determined by your driving conditions driving style and climate. maybe 10w30 is right for you, maybe 0w50 is right for you. that i cant say.
Old Sep 3, 2008 | 06:13 PM
  #32
My tranny usually lets me know when it's time for a change. The shifting gets a little notchy/sloppy. Usually around 1500-2000. This Mobil1 V-twin doesn't seem to stretch the interval like I hoped it would. I have some M1 racing 4T to try next.
Old Mar 7, 2009 | 04:40 PM
  #33
justus222's Avatar
justus222 is on a distinguished road
acid
oil mixes with a bit of petrol as the engines runs, cause the oil to become corrosive. better to change every 3000km
Old Mar 7, 2009 | 05:01 PM
  #34
MLB's Avatar
MLB
MLB is on a distinguished road
Mine gets changed between 1000-1500. It would be a strict 1000 miles if I didn't ride it every day. Anything over 2000 miles is asking for trouble regardless of the oil you are running. These aren't car engines, the oil lubricates the gearbox area too. Also consider the speed of the rotating components. Combine that with the fact that motorcycle oils are not as 'good' as car oils (big topic there, but it comes down to the wet clutch mostly) it all adds up to a lot more wear and tear on the oil.
When buying a motorcycle I always ask about oil changes. When the guy is really proud of the fact that he changes them "every 3000, just like my car", I literally walk away.
That's fine.
Also known as **** to some of us.
Old Mar 7, 2009 | 05:35 PM
  #35
What kind of oil should I use?
Old Mar 9, 2009 | 01:21 PM
  #36
The problem with lighter viscosity oils in motorcycle applications is that pretty much everything under 40W is Energy Conserving, and has wear-reducing additives which *may* allow a wet clutch to slip under load. With regards to an engine whose oil only lubricates the motor, not the tranny, and not one with a wet clutch, I fully agree with most, if not all, of the topics mentioned in the article linked above.
Old Mar 10, 2009 | 10:22 PM
  #37
MLB's Avatar
MLB
Originally Posted by RK1
It isn't about stress on the engine. The oil in cars serves one purpose, lube the engine. In bikes with shared sump, the oil runs through the clutch and transmission as well as the engine.
Bike transmissions beat the **** out of oil. Dino 10w40 oil can become 10w20something within a thousand miles. The additives may last as long as they would in a car but the upper viscosity usually doesn't.
I don't know how much difference it makes. I don't know why Honda engineers reccommend 8k change intervals. I just know oil loses viscosity in shared sump bikes in a fraction of the time it does in a car.
http://www.xs11.com/stories/mcnoil94.htm
Motorcycle Oils vs. Automotive Oils
scroll down and look at the retained viscosities.
I wouldn't go over 2k miles on my bike's oil without a UOA to back it up.
Yeh, those Honda engineers are pretty stupid.
Old Mar 10, 2009 | 10:23 PM
  #38
MLB's Avatar
MLB
Oil does not mix with gas as the engine runs.
The chemical changes that occur to motor oil that cause it to become corrosive are caused by the heat the oil is subjected to.
Synthetic oils properties are not subject to the same process.
Old Mar 10, 2009 | 10:34 PM
  #39
j shizzy wizzy's Avatar
mildly retarded
After Break-in, the manual states every 4.000. I figure every 3,000 to be extra nice to my hawk.
Old Mar 10, 2009 | 11:07 PM
  #40
RK1's Avatar
RK1
I don't think they're stupid. I don't think they're infallible either. If you want to do 8k mile OCIs it's OK with me. Just remember, if that results in an out of warranty oil related failure, Honda engineers won't buy you a new motor.
And if your Honda engineer designed and specified CCTs fail, you're on your own as well.
Old Mar 11, 2009 | 08:23 PM
  #41
MLB's Avatar
MLB
You're right, but I don't think engine oil life has much in common with a particular hard part failure on a particular bike.
Old Mar 11, 2009 | 08:39 PM
  #42
RK1's Avatar
RK1
MLB;
The real reason I change my oil about every 2k miles or a little before is 'cause that's when I start feeling a difference in the shifts up through the gears.
I do know that by 1000 miles most 10w40 has turned into 10w twenty-something. I guess the manufacturers know that too and allow for it.
Still, I can change oil at 2k miles for $10 and get smoother shifts. It's worth it to me.
Old Mar 11, 2009 | 08:53 PM
  #43
autoteach's Avatar
reduced viscosity is why i use 80w-90. Now I can go 10,000 miles on an oil change.
and it smells good to
Old Mar 11, 2009 | 08:54 PM
  #44
autoteach's Avatar
shoot, I lied. sorry, i just go 3000 miles on 10w-40 and treat it nice (highway mileage)
Old Mar 11, 2009 | 09:51 PM
  #45
RK1's Avatar
RK1
Smells good for sure. Would hate needing an APU for cold starts though.
Old Mar 11, 2009 | 10:07 PM
  #46
Yeah, the shear of the gears breaks it down, plus any friction material from the clutch which gets mixed in.
As for change intervals...back in the late '80s, Ford recommended 10,000 mile intervals on the Escort...and you know how many Escorts are still on the road. The car manufacturers currently list long intervals (5,000 to 7,500) to make it seem inexpensive to maintain the vehicle, but they also list in the owner's manual to change oil at 3,000 under severe use...which is every vehicle driven in Southern California or any urban area.
Old Mar 11, 2009 | 11:34 PM
  #47
RK1's Avatar
RK1
Exactly right. 3k miles for severe use plus clutch debris and trans chopping up the viscosity improvers, 2k mile OCI sounds about right to me. If you're using a high quality synthetic you can stretch that a bit but no way would I go for 8k mile changes.
I think it's smarter to pick a decent, affordable oil of the proper spec and viscosity and change it every 2k miles than it is to search for the ONE PERFECT VTR MOTOR OIL and run it thousands more miles.
My current favorite based on research, VOAs and UOAs is Super Tech 15w40 which the Walmart in Valencia still sells for $1.48 per quart.
Old Mar 12, 2009 | 08:23 AM
  #48
CentralCoaster's Avatar
Everyone's an oil expert, isn't it amazing?
I change mine whenever the ghost of Hammurabi starts speaking to my conscience.
Old Mar 12, 2009 | 10:28 AM
  #49
01SuperChicken's Avatar
01SuperChicken is on a distinguished road
Talking
I switched to AMSOIL and a K&N oil filter at the last oil change. I plan to change every 5k.
My commuter seems to like the change to synthetic. It definitely runs cooler.
At the next oil change, I'm going to try the ice coolant additive as well....before summer arrives.
If you're changing your oil before it gets dirty...that's just dumb....not to mention a waste of money....and oil. Unless you are taking weekend track days, then I could understand.
That's like topping off your tank every time you pass a gas station..."just because"
Old Mar 13, 2009 | 04:40 AM
  #50
nnjhawk02's Avatar
Wink
LOL
Wow
My post back from the dead
I switched to semi-syn last year, noticed a little bit of a difference in shifting. With that said I change every 2 to 3 k -
She runs like a beauty
Old Mar 22, 2009 | 10:51 PM
  #51
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
Originally Posted by Zedicus
mobil 1 full synth. 0w40
pure0ne oil filter
6k - 8k oil changes on the bike
8k - 10k in the car
actually could go longer if i would change the oil filter at 4k miles like they recomend and just top off the oil.
also synth has a break in period where it actually is causing a bit more ware then dyno juice would, so if yur running synth and changing oil every 2k miles not only are u wasting money, your doing more harm then good.
and get a good oil filter on the bike, that oil does a lot more then in a car so you want a GOOD filter to keep it clean.
Bottom line is FILTRATION if running full syn oils... This post can go on and on.
I've worked on heavy equipment, where they tested running a good syn oil a full season with a HIGH filtration system, it was like a stack of 6-8 toilet paper rolls in a tall can, all we changed were filters for the season and personally tested the oil (analysis) each time for contaminants. Long term outcome, I cannot attest for, but... oil was always clean.
Anybody stating a $10 oil change on a SHawk, is running recycled oil and NOT changing the filter!
I run Mobil 1 4t (10w40) oil and the "short" Mobil 1 filter for 3-4000mi. I don't analyze it, but it isn't dirty when it comes out. It still costs me $50 for an oil change...
Works out to twice a season and any more is TOTALLY RIDICULOUS!
You should see the metal floating around in the corporate jets I work on, little to no combustion contaminants, but flat out metal... They recommend the same, filters about four times to a single oil change. They run a shared sump for the gear box as well as engine (turbine and fan bearings). A combustion engine WILL create a certain amount of corrosive contaminants which will affect an engine as it sits, but c'mon, it ain't that critical!
LB
Old Mar 23, 2009 | 04:53 AM
  #52
Billzilla15's Avatar
i'm With Scoutpilot. Love Amsoil, Good Stuff, i change it once a year with a new filter, before i store it i dont put on more than 1,500mi in a riding season tho. got other toys to play with, as for my car i run amsoil as well and thats 5,000 on the dot with a new filter (i run the Amsoil Ea0 oil filters as well)
Old Mar 23, 2009 | 06:30 AM
  #53
chickenstrip's Avatar
chickenstrip
Old Mar 23, 2009 | 06:34 PM
  #54
MLB's Avatar
MLB
The thing is, this is 2009.
And it's not just about what makes you feel like you are taking care of your bike.
There are OTHER considerations now that should be considered.
As in: This country dumps 180 MILLION!!! of gallons of used motor oil every year. Only 20 million gallons are recycled. Much of it goes down sewers, but even if you are a good citizen and recycle it, most of it is simply burned as fuel for power plants and such.
Wasteful beyond belief. And helping to ruin our planet.
The 3,000 mile oil change interval is from the SIXTIES!!!! And recommended by the OIL COMPANIES!!
That's for cars of course, but still.......................... wasting perfectly good, irreplaceable oil is not just wasteful. It's selfish. If you think beyond "my bike".
JMO
Old Mar 23, 2009 | 07:19 PM
  #55
Waste oil is also used to oil rural roads and used as fuel for ocean going ships, once they clear the 200 mile limit. But you are right, we all share the same air world wide.
Old Mar 23, 2009 | 07:57 PM
  #56
98ILVTR's Avatar
3,000 miles, and this time I am putting Royal Purple in, I really like this oil, A LOT!!
Old Mar 23, 2009 | 08:40 PM
  #57
RK1's Avatar
RK1
JMO
Like I said, the only reason I change my VTR oil about every 2k miles is 'cause that's when the shift quality goes away. If you're into recycling and long OCI's, I'll leave it in a jug at the bottom of my driveway. You can pick it up, run it in your bike for 10k or 12k miles then send it to the Tennessee Valley Authority to help provide a smidgen of the megawatts Al Gore's mansion sucks up each week.
Old Mar 23, 2009 | 09:10 PM
  #58
About $30,000 per year in utilities if I recall correctly. Way to go Big Al!
Old Mar 23, 2009 | 09:16 PM
  #59
Truckinduc's Avatar
Ha, I live next to a Tennessee Valley Authority Nuclear plant.
Ill be running Amsoil Full Synthetic and K&N filters. I figure changes around 4k Miles.
Old Mar 23, 2009 | 09:17 PM
  #60
RK1's Avatar
RK1
Yep. We could probably save the planet just by confiscating the private jumbo jets of Al Gore and Prince Charles and forcing them to live together in an 800 sq. ft. apartment in Van Nuys.
