How low can you go in 6-th gear, how many revs?
hello riders!
i am asking you how low you can go in 6-th gear? how low the engine is reving before going rough? i can go below 2500 rpms in 6-th gear. ;) |
Yea. 2500 is about it before it starts lugging. But why would you want to ride that way? Fuel economy? Just wondering.
Well mine will pull cleanly from 1500 rpm but I also have cleaned up ports, a HRC jet kit and a lightened flywheel. Even so it really it's all that happy below 3k and I tend to keep it above 5k when I'm riding ;)
Like 8541Hawk my bike isn't entirely stock, and it will pull from around 2000 and up, but why on earth you would go below 3000 in normal riding is a mystery to me... It's not good for fuel economy either... You are defintely not in the part of the powerband that the engine likes...
Despite the urban myth about the low-rpm power of v-twins, they do not like to pull from low rpms (the shuddering should be an indication to any sane person). If you want to pull from low rpm, get a Bandit 1250, you will not be disappointed.....
Originally Posted by mikstr
(Post 271715)
For me, on "everyday" riding I'm normally between 4-6k and if it's a "brisk" ride well I keep it between 6-9k (well it has seen the 10.3k rev limiter a couple of times....lol), 'cuz that's where the real fun lives. ;) |
(Post 271715)
I did the Californian Superbike School Level 1 where you ride the track in 3rd gear without brakes. This sometimes makes the engine revs drop low. The danger is if you snap the throttle open whilst slowing down it can cause engine whip, where the crank slightly over runs the engine speed and as you accelerate it it whips back and can snap the con rod at the piston connection "eye". RD has seen 3 Firestorms and an SP have this exact problem after doing this drill and thinks it could happen to any V-twin. So personally, I wouldn't drop the revs low at all.... |
Originally Posted by steve29
(Post 271712)
in my area there is no other honda vtr to compare., there's only straight hondas :D |
Originally Posted by V-king
(Post 271710)
hello riders!
Originally Posted by nath981
(Post 272067)
in order to redeem yourself and to prove that you really are the V king, please tell us the most rpms you can get out of sixth gear. :D
There is a couple of other issues with the engines when loading them up down low. It places a lot of load on the crank and rod bearings. This load also occurs when there is little hydrodynamic lubrication, this can allow the bearings and journals to come into contact (normal operation they are separated by the oil) and cause premature failure. Another problem is cam chain slap. Singles and v twins are more prone to this than say an IL4. Anyone that works on a lot of agricultural model bikes or quads will see the effects of this one quite often.
Originally Posted by colinlinz
(Post 272076)
(Post 272076)
Originally Posted by 8541Hawk
(Post 272073)
I know that answer..... ;)
(Post 272114)
that info can garner you a hefty fine and a 365 day vacation from riding, huh.
(Post 272112)
you've convinced me. With the paultry hydrodynamic lubrication characteristics of the superhawk, I've decided to unhook my plow/mower attachment and vow never to perform ag tasks again. thanks. :D
Just to clarify the hydrodynamic lube remark. My apologies if this old news. Engine slipper bearings are designed to a diameter that will take advantage of this style of lubrication. As the linear speed between the bearing and the journal increases, a wedge of oil is formed. This increases the oil pressure acting between the two moving parts, and keeps them separated. Sort of like water skiing, when you go fast you sit on top of the water, when you slow down you sink below it. With this in mind, engines that are designed to rev slowly will have a larger circumference journal, so that an adequate speed differential can be maintained. Like most things, you can have too much of a good thing, so there will also be a speed differential that will be too high. That's why engines that spin at high rpm have to consider not going too large in circumference. I sometimes think that the VTR is too good an engine. As has been stated already, Vtwins are usually more snatchy down low. The VTR's willingness to rev low and not become as snatchy could lead people into using this area of operation more than they would with another Vtwin. Whether this will be a problem I have no idea, but it is something I try and avoid. Whether this has had anything to do with my lack of CCT failures (80'000+klm without a problem) I can't say, but I am happy to keep trend going and see what happens. |
The BMW R100RS that I owned for 15 years would cruise all day at 2500 rpm. But My first ride to work on my SuperHawk in '05 told me, through my seat of the pants dyno, that the VTR prefers to run at 3000 rpm and higher.
My wife's SV650S doesn't like it much below 4000 rpm (11,000 rpm redline). It comes down to...the higher the redline, the higher the cruising rpm. You can run a Harley at 1500 rpm all day, but look at the redline...I haven't checked lately, but I think it's something like 4500 rpm for a Harley. |
(Post 272201)
(Post 272203)
Actually I think most of them, the newer at least is somewhere between 5000 and 6000... The V-Rod actually has a 9000 rpm redline... :eek:
While not a Harley owner myself.. I do think that Harley bashers should try riding a new Harley at least once. (Rent one some weekend when you are out of town)
They are not the POS bikes of the 80's anymore. |
(Post 272192)
I don't know what it is with farmers, but they do seem to like to lug their engines. My father in law does it all the time. I was talking to a technical trainer from Honda (AU). He was saying that this market sector was where they do experience a lot of timing chain, guides, and CCT failures, mainly because they lug their engines a lot, rather than let them rev. Oh, and just to clarify that slightly, the trainer was talking in general manufacturer terms, not just Honda. He was tech trainer with Suzuki (AU) before moving to Honda.
Originally Posted by lazn
(Post 272205)
They are not the POS bikes of the 80's anymore. Contrare my friend. It's like buying a new 1936 ford, but paying the price of 2010 mustang, the exception being the V-Rod which is not a true hog. I have ridden one during a demo ride at daytona and wasn't favorably impressed. They make antiquated, overpriced garbage and should have been bankrupt long ago if not bailed out by tariffs imposed on foreign manufacturers. |
(Post 272208)
What is antiquated about them? The fact that they aren't OHC? So what? Neither is a Corvette ZR1. The fact that they are aircooled? Again, so what? Less to break. Sure they could upgrade those things and get more horsepower, but they don't need more horsepower.. You can't expect a train to corner like a lotus.. for their purpose they are good. Are they overpriced, image bound, status symbols? Yes I will totally agree with that. But are they 1937 technology?? They are higher tech than the VTR.. So take that as you will. If you are going to bash them, do so intelligently, not for things they no longer are. |
Not to get into an argument about OHC vs OHV, but the early '90s ZR1 had a DOHC 32 valve engine. However, down low it didn't perform any better than a standard pushrod V8 Corvette of the same year. Chevrolet dropped it because of the cost of the engine, and because in around town driving it was lacking in low rpm torque. And it cost almost double the standard 'Vette, at $90,000 if I recall.
(Post 272283)
Hmm, they are all fuel injected (unlike our VTR) they last pretty good, they no longer leak, they all (at least stock) handle pretty well, their paint and chrome is better than anyone else, ABS is available, etc etc..
What is antiquated about them? The fact that they aren't OHC? So what? Neither is a Corvette ZR1. The fact that they are aircooled? Again, so what? Less to break. Sure they could upgrade those things and get more horsepower, but they don't need more horsepower.. You can't expect a train to corner like a lotus.. for their purpose they are good. Are they overpriced, image bound, status symbols? Yes I will totally agree with that. But are they 1937 technology?? They are higher tech than the VTR.. So take that as you will. If you are going to bash them, do so intelligently, not for things they no longer are. They make high profits for low quality products and that's why companies like these should no longer exist. For example, when the japanese suv's became popular, ford dressed up their explorer and sold it for comparble prices. Of course it was masked junk and it later surfaced that they made $10,000 profit on each Ford Explorer. These things were overpriced, japanese wannabe masqueraders. The japanese did a hell of a lot better than ford at their HD simulations. It took the american people way longer than me and way longer than it should have to realize the agenda of these second rate companies. HD wouldn't even be here if consumers were at all discerning and/or were looking beyond the name. If you think that HD or these bailed out domestic automakers compare favorably with real companies like Honda, BMW, Aprilia, KTM, Toyota, etc. then that's your perogative. Trade you antiquated SH in for one of those modern high tech hogs with slapped on fuel injection, ABS brakes and superior chrome see if you're happy with what you got for your money. Argue intelligently! you mean like a lawyer? maximize the importance of little things and minimize the main points. Well it does work I guess...OJ got away with a couple murders. |
Nath..."Using those shit engines did Buell in and HD couldn't even build their own V-Rod. They have to let foreign companies or others like S&S do the job right. Compare HD, general motors, ford with honda or any other similar competitive progressive company and the obvious thing that pops out at you is that you don't get what you pay for, you don't get real value for your money in terms of quality, and that's enough of a deterrent for me".
Not sure if my Buell Lightning has a shit engine, mine's an 03 1000cc and honestly runs sweet, never been a problem and all I've really done is oil changes! not one oil leak, not one misfire, so no complaints.. That said, I personally am not a HD fan, but you have to say kudos to one of the best marketing and branding turnarounds of the 20th Century. If folks keep buying 'em, they'll keep building 'em, a la GM, Ford and the rest! :rolleyes: |
(Post 272283)
Originally Posted by CANADAVTR
(Post 272383)
Not sure if my Buell Lightning has a shit engine, mine's an 03 1000cc and honestly runs sweet, never been a problem and all I've really done is oil changes! not one oil leak, not one misfire, so no complaints.. That said, I personally am not a HD fan, but you have to say kudos to one of the best marketing and branding turnarounds of the 20th Century. If folks keep buying 'em, they'll keep building 'em, a la GM, Ford and the rest! :rolleyes: As far as people buying them despite their poor value I have to say that these are people who trade in every three to five years meaning that anything will last that long. In spite of this, they still would have went down which would have been justice for all the years they put out poor quality products, bought out patents for fuel efficient technologies and buried them, intentionally programmed failures to encourage buyers to trade more often, etc., etc. |
Hi Nath...no worries mate! I did'nt take your comments personally, and agree with your thoughts about HD as a brand! And if they would have kept the Buell with the Rotax 1125...
Funnily enough, I needed a new battery for the Buell so went to the HD store in Oshawa yesterday. $143 poorer now! Took a look around all the HD stuff...marketing at its finest..but I agree 100% with you...the bikes are big, lardy and wayyyy too much money! Even the '06's were almost $20K. So Saturday afternoon, to offset the pain of a $143 battery, I went out on the VTR for 3 hours. Two gas of gas and the best fun you can buy for $3,000. Bargain! |
(Post 272491)
