SuperHawk Forum
-   -   how long for bearing failure? (https://www.superhawkforum.com/forums/technical-discussion-28/how-long-bearing-failure-25333/)
nykuryu Apr 24, 2011 10:35 AM
how long would you have to run contaminated oil with coolant to ruin a bearing?
K30 Apr 24, 2011 12:35 PM
Not long, if you have milky oil you need to flush everything ASAP.
When breaking in an engine/firing for the first time, you always use distilled water instead of an antifreeze mix just in case there is a leak somewhere. It doesn't take much time to damage internals.
nykuryu Apr 24, 2011 01:19 PM
Well i had a gasket failure awhile ago and am just trying to get ideas while not having the bike with me. I might have ran the bike for like a minute with the really bad oil. Oil was fine before the big failure.
