Help I think I screwed up?
I have a 99 Superhawk with only 8000 miles on it, a month ago it started to make a knocking noise from the front, I turned off and when I try to restarted the bike the engile was locked, everyone I talked to said is the CCT, si i went ahead and took the rear valve cover and it looked ok to me the cam chain did not look loose so I went ahead and like a dumb took the cam shaft holders and you know whta happen next, I can't put the camshafts back because I did not loosen up the CCT? what can I do? I think the CCT that when bad is the front one and not the rear one. Any help please.
take the cct out...you can reset it once it's out.
you need to check the front cylinder. You have to time the motor now. Look in the service manual.
(Post 136315)
I think is worst
I took my fron sparplug today and the tip of the sparplug looks like if got hit with a hamer, I also took the whole valve case out and there were to 6mm bolts that were broke. I also took the oil pan off to check if there were any pieces of metal, and guess what there were some small pieces of metal. so I dont know is is worthed to keep digging in or just cut my losses and sell the bike for parts. I only pay 2500 for it.
engine proplem
I have a complete engine for sale in Florida
Originally Posted by 8541Hawk
(Post 136338)
Not really, once the CCT goes to full extension it is pretty much shot and must be replaced. At this point you would need to get some new CCTs ( of whichever type you like) and replace them both.
(Post 136346)
Actually they can be retracted... otherwise you'd be up a creek when you removed the cams to shim the valves. Remove the 8mm bolt.. behind that is a flat head type screw... wind that clockwise to retract the tensioner.
Engine!
Do find a good used engine and forget that canoe anchor. Or, part it down and get a newer Hawk!
rebuild is pretty cheap with a donor engine
I threw a chain on my hawk and cracked the cases. New cases were 1500 bucks my cost as an employee. I found a donor engine for 250 bucks. Took what i need and replaced what was needed and built a whole new engine for under 600, my cost that is:cool:. it is a very very very simple engine to rebuild. And if you need help, just buy the Honda Service man. Pretty good step by step foryou first timers, and fair to decent tips for us salty dog engine builders. but for your problem, definately a complete tear down sorry dude
Originally Posted by joenuzz
(Post 136448)
E-Bay....
I already look in ebay and nothing, I found some websites to buy parts but they racking up in price real quick, so far i'm looking at 500. I may just spend 500 more and buy me a engine.
