SuperHawk Forum
-   -   Help I have wheels from?? (https://www.superhawkforum.com/forums/technical-discussion-28/help-i-have-wheels-22173/)
boxdogracing Apr 11, 2010 04:18 PM
O.K flebay strikes again! About 6 months ago I bought chrome rims off Ebay, add said: "chromed rims from 99 superhawk never mounted". I received them looked them over for damage and set them aside. this weekend I decided to mount them... Well there NOT superhawk rims. Both rims use larger bearings, the front needs rotors with a larger center hole and I think the rotor bolt pattern is slightly larger. Also the rear needs a 6 bolt rotor. These are just the differences that became apparent with a fairly quick second look.
The real problem here is of the thousands of bikes out there, all I know is they are not superhawk wheels. They have the same appearance as stock wheels, but all the casting identifications where ground off to prep for chrome. Looking for help to identify what they came from. Then I can see if mounting is possible, or at least sell them to someone who can use them. Thanks guys, any help here would be greatly appreciated.
alive226 Apr 11, 2010 04:37 PM
Pictures would probably help.
8541Hawk Apr 11, 2010 06:10 PM
I bet they are for a VTR1000 SP1\SP2 or a RC51
Well I guess I should read your whole post. If they have 3 spokes then maybe 954 or 1000 wheels
boxdogracing Apr 11, 2010 06:30 PM
I also thought SP1/SP2 or RC51, but yes they have three spokes, 954 or 1000 are possible. how would I check they did not come with bearings or spacers, all I have is bare rims with no casting marks.
inderocker Apr 11, 2010 07:55 PM
I assume the seller is not accepting returns?
residentg Apr 11, 2010 08:03 PM
Hawk NT650's have 3 spoke wheels. If I saw the pics, I could tell. JB
autoteach Apr 11, 2010 08:18 PM
cbr F4?
boxdogracing Apr 12, 2010 01:24 PM
After hours looking for a Honda rear rim with a six bolt rotor, I found CBR1100xx looks the same. Anyone know how to verify this. If that is what they are, anyone know if they could work on a superhawk?
inderocker Apr 12, 2010 02:58 PM
As far as the 97-98 CBR1100XX goes, the front wheel is a drect swap to the VTR, the rear wheel however has a much larger and wider hub and will not work on the VTR.
supermarto Apr 12, 2010 03:29 PM
Do they have part numbers stamped someplace? I thought they do... If so, check servicehonda's part # reference?
boxdogracing Apr 12, 2010 03:57 PM
The rear hub does look big and wide, but the front does not swap either. Maybe a newer 1100xx? All casting #s where ground off to prep for chrome.
