Heavy spring maintenance
Old Mar 16, 2008 | 07:19 PM
gboezio's Avatar
The winter is almost over and I'm waking up as my *** is defrosting slowly.
So I figured I could tear the bike down, I went to buy a few lost sockets and beer. A few beers later the bike looked like a major wreck...
My forks really sucked and I almost killed myself last summer from a tankslapper so I got on it I took out these crappy stockers pig tails.
The fluid on the first fork looked pretty good
But the second looked like black dust on it and had a real bad look
I think safety when I choose a place to put my gas tank, I can trip on it while drunk.
Got to bring the rear slug to TDC
Lookin good
Then I attacked the valves inspection...and it failed, on the rear head I had 0,011 and 0,013 on the kyoto side witch is good, but on the intake, I measured 0,002 on both specs are 0,006 +-0,001
So I had to pull the cams, I had to make some custom CCT holder tool from a 1 buck SD
Pulling the lifters, quite easy with a magnet
I could not read all the numbers on all the shims, so I guess I will need to get a caliper to measure them, then I'll be able to order the right ones
I hate to mix lifters, they tend to make a specific wear pattern
That was the easy one, let's do the funniest one
The rear bolts of the front cover are a real PITA, got to loosen all therads and oil cooler to get them
A quick check to the chain and even if it looks good the links are too stiff and it's junk (32000 km on it witch is not too bad)
What is causing the fork oil to turn this silly color, Water ??
gboezio's Avatar
Second post reserved
Old Mar 16, 2008 | 07:42 PM
calitoz's Avatar
Escape Reality
Excellent work
Old Mar 16, 2008 | 08:15 PM
cliby's Avatar
busy day! is that small scissor jack really all that is supporting the front end?
Old Mar 16, 2008 | 08:35 PM
gboezio's Avatar
Yeah lol I have to think of it not to wrench too hard or the gravity will claim it's due
It's resting on the sidestand and the jack replace the front wheel
Without the forks and wheels weight, it's pretty stable
Old Mar 17, 2008 | 03:37 AM
Yep... water, heat and a lot of compressions... usually it smells kinda funky to... like rotten eggs... With oil like that I'd say swap every possible seal you can find...
Old Mar 17, 2008 | 06:57 AM
superbling's Avatar
If you haven't all ready, give the forks a good rinse or two with kerosene as there's more gunk in them.
Love the tank safety shot. Would have been better with a cigarette jutting into the edge of the picture! LOL
Old Mar 19, 2008 | 08:57 PM
brownrxmd's Avatar
brownrxmd
LOL
I absolutely loved that post, i wish I knew how to do what you did! Awesome
Old Mar 19, 2008 | 11:31 PM
Spaz''s Avatar
Spaz' is on a distinguished road
Smile gboezio
GBoezio,
Great post - very well done work to share with us. My bird is an '01 with 24,150 miles on her. I purchased it a year and a half ago with 16,600 miles on it and the previous owner did not have the 16k valve lash check performed. I've heard people who have gone awhile with their Superhawk's and the valve lash being within spec' beyond 16k...
So my questions are, how many miles are on your bike? How many miles have gone by since the last valve check/adjustment? And how many miles are on your fork fluid since its last check/change?
Old Mar 20, 2008 | 03:28 AM
gboezio's Avatar
Little update, bad tools bit me ***, but on the positive side I realized it before tearing apart the front cams, I figured that my 0.0025 feeler gauge was waaay thinner than the 0.004 and that 0.006 was also thicker than the 0.007, I found it dumb not to include 0.003 and 0.005.... You see me coming don't ya
The were so well stuck together that I had to ditch this piece of crap after screwing up the end of it with a box cutter to try to pry them apart to no avail... 0.007 no go then 0.006 (+0.005) no go then 0.004 (+0.003) no go of course, then the 0.0025 will go in wrote that down...0.0025
Bought a Gray tools new feeler gauge so It won't be happening again.
Final results after 32000 km (20k mi), I ended up replacing only a 0.004 intake shim that I would leave in there, but I had my cams taken out so it's done.
all exhaust within specs 13, 11, 11,11 Intakes 5, 5, 5, 4 /1000 in
My torque wrench is too big for the cams holder and too cheap for comfort and too due for a calibration, so I ordered a new 3/8 10-100 lb/pi TQ wrench
Just finished to order my 0.85 Racetech springs and stock replacement chain set.
Now sipping coffee, working my *** off and waiting.
I bought a electronic caliper too, but these are tools that I wanted for a long time and That cheap *** feeler gauge at least gave me a reason to buy them
Fork fluid was stock, I never touched the bike except the carbs last year.
Old Mar 20, 2008 | 09:29 AM
RCVTR's Avatar
I was kind of waiting for that. I didn't think your intakes would have closed up that much.
That workstand makes me nervous! Can't you strap that thing up to the ceiling??
Old Mar 29, 2008 | 05:13 PM
gboezio's Avatar
I received my RT springs, here they are by the rubbish originals
Since they are longer I had to cut the spacers
YEAH BABY !! It seem that I remembered where all this stuff goes
So I went for a spin, god damn I should have done this before, it's like a sportbike, now I can ride without fear to hit a bump and fly off the road.
Greatest mod to date.
Incoming summer
Old Mar 29, 2008 | 05:57 PM
drew_c14's Avatar
Very nice! How much did you have to cut off of the spacers for the .85's?
Old Mar 29, 2008 | 06:26 PM
Incoming summer
I appreciate your comments about the "new" bike because it really is once you get the bike's suspension to work with you and not against you.
I also really liked the "safe place" photo of the gas tank on the heater. You could take "block party" to a whole new level with that one!
Thanks for another one of your award-winning photo documentaries. Your Europe trip last year was great. This one is equally good. Happy trails!
Old Mar 29, 2008 | 08:28 PM
gboezio's Avatar
The stockers were 100mm, My calculations were 74,3mm well 75 is good enough, I have a good 1" of front SAG, adjustments are pretty far, like 80 % in, someone could use 5mm longer spacer, I'm 160 lbs
Work against me you say, the damn thing tried to eject me last fall
I wrote this thread last fall, https://www.superhawkforum.com/forum...ad.php?t=13040
Nothing in broken in there, just bad springs from the start.
Thanks for comment, as I always say; if someone takes the time to read it, it was worth the time to write it
Blue Ridge Boy
May 1, 2008 07:33 PM
gboezio
Oct 6, 2007 11:57 AM
Tempest
Sep 13, 2006 12:01 AM
E.Marquez
Jul 19, 2006 08:38 PM
