fuel question
Old Mar 4, 2010 | 06:22 PM
gixxerjohn's Avatar
gixxerjohn is on a distinguished road
fuel question
ok guys i want to check this with you
bike has its pair system removed.
there is a line coming off the rear cylinder, vacuum line this connects to the rear of the petcock i believe?
there is the front line coming off the carb, which used to go to the pair, its plugged.
the bike has A LOT of backfire, with a dj kit, running dj specs, 4th clip, 2.25 turns out.
am i missing something ? to me the way the bike is acting is an air leak somewhere....
suggestions/ideas??
cheers
Old Mar 4, 2010 | 07:15 PM
Third Echelon's Avatar
Third Echelon is on a distinguished road
running too lean maybe? what jets/exhaust combo are you running?
Old Mar 4, 2010 | 08:09 PM
gixxerjohn's Avatar
180/185 2.25 turns out, jardine high mounts, stock filter, pair removed, etc......
just did a lil tweaking, did a lil sync on the carbs, prob seems better, will check again in the am when i can actually put load on it
Old Mar 4, 2010 | 08:17 PM
RK1's Avatar
RK1
FWIW
Spec on the pilot screws is 2.5 out on 49 state bikes, 2.75 on California models.
Old Mar 5, 2010 | 03:00 AM
suggestions/ideas??
cheers
I'd double, triple quadruple check all the airlines involved in the PAIR removal... It's very easy to miss one, people have done it several times... Also the plugging might be leaking somewhere?
Other than that,like others have said try fiddling with the pilot screw... Those big honking carbs are might picky sometimes... Getting it half right is easy... Getting it spot on takes some tinkering and a few curses usually...
Old Mar 5, 2010 | 09:19 AM
gixxerjohn's Avatar
hahah aint it the truth, thats why i enjoy lambada tuning lol on fi bikes
but the bike is fine for now, it will hit the dyno and get a fine tune
Old Mar 5, 2010 | 05:33 PM
That's cheating...
Fox
Dec 14, 2010 11:46 AM
seb421
Feb 4, 2009 05:49 AM
bluethunder
Jun 3, 2007 04:56 PM
hoghead5150
Mar 24, 2007 01:37 AM
AbeFM
Sep 26, 2005 09:47 PM
