fuel question
ok guys i want to check this with you
bike has its pair system removed. there is a line coming off the rear cylinder, vacuum line this connects to the rear of the petcock i believe? there is the front line coming off the carb, which used to go to the pair, its plugged. the bike has A LOT of backfire, with a dj kit, running dj specs, 4th clip, 2.25 turns out. am i missing something ? to me the way the bike is acting is an air leak somewhere.... suggestions/ideas?? cheers |
running too lean maybe? what jets/exhaust combo are you running?
180/185 2.25 turns out, jardine high mounts, stock filter, pair removed, etc......
just did a lil tweaking, did a lil sync on the carbs, prob seems better, will check again in the am when i can actually put load on it |
FWIW
Spec on the pilot screws is 2.5 out on 49 state bikes, 2.75 on California models. |
Originally Posted by gixxerjohn
(Post 256199)
bike has its pair system removed. there is a line coming off the rear cylinder, vacuum line this connects to the rear of the petcock i believe? there is the front line coming off the carb, which used to go to the pair, its plugged. the bike has A LOT of backfire, with a dj kit, running dj specs, 4th clip, 2.25 turns out. am i missing something ? to me the way the bike is acting is an air leak somewhere.... suggestions/ideas?? cheers Other than that,like others have said try fiddling with the pilot screw... Those big honking carbs are might picky sometimes... Getting it half right is easy... Getting it spot on takes some tinkering and a few curses usually... |
hahah aint it the truth, thats why i enjoy lambada tuning lol on fi bikes :)
but the bike is fine for now, it will hit the dyno and get a fine tune |
(Post 256265)
