Front wheel - warped
Old Jun 7, 2010 | 02:20 AM
residentg's Avatar
I discovered that the front wheel of the wreck that we are rebuilding has about a 1mm run-out. I see this from the inner most part of the side bead, and it is on both sides of he wheel in tandem, so it is actual run-out.
Looking for opinions: is this something that I should worry about? Will it matter at 100mph? We are trying to keep the expenses down. Thank you. JB
Old Jun 7, 2010 | 04:27 AM
bjorn toulouse's Avatar
Destructive Tester
Radial or axial run out?
Rex
Old Jun 7, 2010 | 07:08 AM
Erik S.'s Avatar
I have a front rim at the house doing nothing. Let me know if you need it. I can take the tire and rotors off, and it's yours for cheap or trade. Do you have a double bubble windscreen you don't need?
Old Jun 7, 2010 | 07:11 AM
Little_Horse's Avatar
2nd mouse gets the cheese
1mm isn't very much, I don't think it would be dangerous, but there is a chance it will vibrate at a certain speed.
Old Jun 7, 2010 | 08:29 AM
Erik S.'s Avatar
BEFORE THIS TURNS INTO ONE OF THOSE THREADS WHERE EVERYONE GUESSES AND THINKS AND SUPPOSES...
The definitive answer is:
In the service manual on page 1-9 Wheel rim runout Service Limit is listed as such:
Radial: 2.0mm (.08 in)
Axial: 2.0mm (.08in)
Resident, if you only have 1.0mm, you are well within the factory Service Limit specifications.
Carry on with your normally scheduled conversations.
Erik
Old Jun 7, 2010 | 08:40 AM
Destructive Tester
Yeah, like that ever happens!
Rex
Old Jun 7, 2010 | 08:46 AM
Old Yeller's Avatar
Erik
Rex
Crap...I was hoping we could give him all sorts of mis-guidance. Dang smarty pants.
Old Jun 7, 2010 | 08:48 AM
residentg's Avatar
Radial (side to side). It may even be less than 1mm, I have not yet put a dial on it. Erik - thank you for the offer! lets see if I need to take you up on it. Thank you again.
The left rotor is off by almost 3mm, I have secured replacements already, I am pretty sure that 3mm in out of spec
JB
Old Jun 7, 2010 | 09:11 AM
Erik
Easy now...
It wasn't a guess it was an opinion.
I would run it.
and you looking it up the numbers verify I was right anyways.
8541Hawk
Sep 18, 2010 05:17 PM
jaypo
Nov 9, 2009 06:24 PM
Hotbrakes
Nov 7, 2008 01:21 PM
Randman
May 22, 2006 05:18 PM
Loco
Apr 12, 2006 07:24 AM
