A friendly reminder...
Old Sep 28, 2009 | 09:07 PM
j shizzy wizzy's Avatar
mildly retarded
to check your tire pressure.
Old Sep 28, 2009 | 09:42 PM
This is a good call, J! It has been so hot here that keeping up with this has been a no-brainer - if they're low - they'll get hot. Not anymore.
Old Sep 28, 2009 | 09:48 PM
36 front, 38 rear
And watch those chickenstrips.
Old Sep 28, 2009 | 11:19 PM
factory is 36f/42r. I like 4 pounds off factory - Chas likes it much softer. Last time I checked the bike it was 21f/20r. That **** got changed.
Old Sep 29, 2009 | 04:34 AM
uchi's Avatar
i was running 41 rear and found i had the back tire lock up a few times on downshifts on me and also step out a little through some corners. went back to 36's seems alot more solid
Old Sep 29, 2009 | 12:20 PM
swordfish's Avatar
36 front, 38 rear
what chicken strips?? haha
funny you should mention this. I checked my pressuer over the weekend, and found a discrepancy between what my tire pressure guage said and what the guage on my pump said. so I bought a new guage to see which was right. the pump guage was right. my old tire pressure guage is reading about 10 psi low. scary
Old Sep 29, 2009 | 10:17 PM
FlamFlamMan's Avatar
FlamFlamMan is on a distinguished road
Seems like everyone here like the pressure a little lower than factory on the rear. I'll have to try, but I've never had a problem w/ the recommended pressure. I guess I'm just to new to this to need the extra grip; I'll have to learn to ride harder
Old Sep 30, 2009 | 09:39 AM
runrowdy's Avatar
runrowdy is on a distinguished road
I would but my tires are officially shot. It's been a good summer! Waiting on some Q2's to come in. I'll be ready for spring though!
Old Sep 30, 2009 | 04:18 PM
stebbdt's Avatar
COBB Member
Great heads up, found mine low about 10lbs each last week after having the rear break loose on me unexpectedly.
Old Oct 1, 2009 | 04:50 PM
D VTR RIDER's Avatar
D VTR RIDER is on a distinguished road
If you want your tires to last go with stock pressures. If doing twisties and want more grip, you can drop the pressure 6-10 lbs lower. Factors to think about is ambient outside temperatures, single or 2 up and length of ride. Low temps need a lower pressure to get heat into the tires. 2 up will need more air. If at the track you can drop it all the way down to +/- 29 lb. Tire life never enters the equation at the track, only traction.
The point being is that there isn't one perfect tire pressure for all riding.
If the rear tire chirps when down shifting, learn to blip the throttle.
Old Oct 2, 2009 | 04:38 PM
nath981's Avatar
+1
I run low 30's unless riding 2 up or touring. I can tell if the pressure is in the ball park by pushing on my tires since i do this each time before I ride.
Old Apr 22, 2010 | 08:39 PM
mildly retarded
bump
Old Apr 22, 2010 | 11:04 PM
Good call - It's that time again and some guys have spooned new tires over the winter so little bead leaks, valve stem gremlins, all gotta be watched. And like Swordfish reminds us - maintenance includes the tools. I've thrown more than one tire gauge away because it couldn't be trusted. This is especially true of the bike tires and the 4-wheelers. I run 4-6 lower than factory front and rear.
Old Apr 23, 2010 | 01:03 AM
ranchomice's Avatar
Good call, weather is changing 34f-36r here.
Old Apr 23, 2010 | 11:12 AM
PUSHrod's Avatar
Pre-flight every ride:
Tire pressures/tread
Chain lube/slack
Oil/brake fluid/gas
Lights
Leaks
Really now, who doesn't?
Old Apr 23, 2010 | 12:35 PM
steve29's Avatar
steve29 is on a distinguished road
+1 on that
Old Apr 23, 2010 | 01:01 PM
36 front, 38 rear
This last winter with cooler and sometimes damp asphalt on my favorite canyon road, I was running 32f and 35r.
Old Apr 23, 2010 | 02:16 PM
RCVTR's Avatar
I had a tire pressure gauge that also read about 10psi low! I discovered it because I would fill the wife's tires on her car and the tire pressure light kept going off.
It's a good idea to get your gauge checked.
Old Apr 23, 2010 | 03:01 PM
I use a Blue Point dial type gauge from Snap-on. About $14 when I bought it. When I was teaching we would keep 2 of the Blue Point gauges and about 3 pencil type gauges in the tool room. I'd periodically check them against each other, and toss the bad ones after breaking them, so they couldn't be used any longer. In about 10 years with the Blue Point gauges getting extensive daily use by my students and night class students, one had to be replaced when it became inaccurate.
It's a good idea to keep a couple of gauges, and check them against each other from time to time.
JPP
Aug 6, 2010 12:32 PM
8541Hawk
Jun 2, 2010 08:40 AM
sassage
May 28, 2008 04:07 PM
Chuey
May 15, 2007 10:51 AM
superhawk22
Jan 21, 2006 12:48 PM
