Fork Brace vs Steering Stabilizer?
So I was trying to decide between a fork brace from truck or a steering stabilizer as funds do not support both. Just wondering what everyone's opinion is if they had to only go with one over the other.
In your riding: Are you experiencing tank slappers, or fork flexing?
what would the fork flexing feel like? It is more of a confidence issue with cornering I guess.
The VTR is a very stable bike, so a steering damper is not needed.
The 41mm forks on the the other hand suffer from flex. A fork brace is a good addittion. |
On the other hand, the best investment for improving cornering confidence is to improve your skills. This could be done by doing a track day, or riding with and getting some instruction from those who have the skills you're looking for.
Fork flex is simply that you turn the bars and the front is turning more or less than your input because the gyroscopic force is acting against you, or that the fork "twists" while leaned over... Believe me, when you have felt it you will know... It's not funny...
A steering damper on a stock VTR is completely unnecessary... If you change the geometry for faster steering and do hard riding on a track it becomes useful... With a inexperienced rider on the street it can be outright dangerous... My advice, if the rest of the bike is stock... Go with a brace, it helps stiffen the front and is an advantage in nearly any conceivable situation... |
Originally Posted by shayne
(Post 216100)
The 41mm forks on the the other hand suffer from flex. A fork brace is a good addittion. For building confidence, go to a large empty parking lot. Free from car traffic. Using cones, soda cans or whatever you can find, make two 90 degree corners. One to the left and one to the right. Then practice using different approach angles to help you round the corner. Start off slow and gradually increase your speed and lean angles. If you make a mistake(running wide or cutting in) you'll have plenty of run off room to correct yourself. Also ride in a big circle. With each pass make it smaller. Your lean angle will change. This will help you learn how to lean over. Make sure you don't get too dizzy. This will help you develop better cornering skills without running off the side of the road or endangering anyone else. |
thanks for all the input. It isn't that I am an inexperienced rider, just looking to make the Hawk better. I had Greg do my forks last year so the suspension isn't stock anymore. Just never satisfied with the way it is I guess...bigger, better, faster...I'm sure most of you on this forum understand that :headbang:
having both... i'd go with the fork brace before the damper.
if you havn't setup the front forks, after the rebuild, then get to a suspension shop and pay the basic setup fee ( $40 around here ) and have them set the sag and the rebound. tim |
Originally Posted by chickenstrip
(Post 216104)
Originally Posted by superhawk22
(Post 216120)
+1 I did a lot of trackdays before i really felt the need to improve the front end money well spent IMO, plus it's a lot more fun to drag a knee than install a brace. ;) But I do agree with the others if you want to do it go for the brace first.
imo: #1) replace the front fork springs #2) EBC HH front brake pads hit the track ! once you get used to the track you'll start to feel the limits of the bike #3) revalve the forks #4) upgrade the m/c & cailiper & pads & brake lines #5) fork brace #6) rear shock #7) steering damper tim |
Agreed but you can have some good fun before you HAVE to get into mods, BTW my list went braided lines, rear sets, then suspension but everyone will have thier own opinons on that oh and the list is to long to go into right now. :lol:
Originally Posted by trinc
(Post 216138)
i hear this alot and although i agree that the track is a great place to learn it also shows how lacking the bike is ( in stock form ).
(Post 216138)
Seriously? I reworked your forks over a year ago! You haven't set sag and rebound yet? Get busy, Doc! Once the forks are working for you then you'll find the bike is stable and neither of the above are necessary. Save up for the aftermarket rear shock or use the Visa card now and be done with it.
Ya, I know. I have only put on on 175 miles since I got the forks back. Was actually going to sell the Hawk due to lack of use. Besides, I swear I am in the land of Deliverance here. There are no tracks, no suspension shops, hell, even no bike shops other than the Honda car dealership that has a 50 square foot area set up to sell motorcylces at their dealership. I called there yesterday to see if how much they charge for a suspension set-up and they told me the sag and rebound can't be adjusted on the Superhawk!!!....I hung up!
