Fly hitting a bug zapper
Old Aug 25, 2006 | 05:02 AM
chewpick's Avatar
chewpick
That's the sound my 98 VTR made this morning when I went to start it. Something definately got fried cause I could smell "that burnt electrical" smell right after.
It happened as I pressed the start button. Everything just died. Now when I turn the key to on, there's no lights or anything.
Two questions:
1. Anybody encounter this before?
2. Any idea where to start diagnosing this?
Thanks
Old Aug 25, 2006 | 05:07 AM
Two questions:
Thanks
All power is dead?? Start at the battery.. Check the connections,, check with a volt meter, check the ground wire from battery to motor.
Old Aug 25, 2006 | 08:09 AM
ATLSHawk98's Avatar
ATLSHawk98
pull the main fuse inline after the battery. check it first. mine would blow this fuse everytime i turned the ignition when my R/R was going bad. replaced the R/R a couple days later and all was well.
good luck!
Old Aug 25, 2006 | 11:33 AM
blokeontheend's Avatar
blokeontheend
note: R/R = regulator/rectifier - a common problem with the SH. So far it hasn't occured on my 2002. Perhaps it was corrected by then. Good luck.
Old Aug 25, 2006 | 02:10 PM
RickB's Avatar
I have had a battery quit out of nowhere before on my 92 Nighthawk 750 (older lead/acid type) something internally just let go . after sitting a bit it would run the lights nice and bright but the it would go completely dead when you tried to start it - I don't know if the sealed batteries can die like that but you never know.
The '02s and later VTRs have a reworked r/r unit with cooling fins.
Old Aug 28, 2006 | 04:46 AM
chewpick's Avatar
chewpick
Well, I'm a dope.
I went up to the store to buy a voltmeter, and by the time I got back my father, who was visiting, came out and fixed it. Turns out the connectors for the battery were not on tight at all.
I had just had the bike in to the shop 2 days earlier and I remember them saying they checked the charging system.
Thanks for the replies....I'm glad it was this simple.
Old Aug 28, 2006 | 06:00 AM
jschmidt's Avatar
jschmidt
This is a good learning experience. Internet advice always starts at the end of the diagnostic chain and moves backwards.
Your dad, benefitting from not being here ;-) , started at the beginning and found the problem right away.
Old Aug 28, 2006 | 07:20 AM
chewpick's Avatar
chewpick
haha...touché jschmidt
At least I didn't ask if it was my CCT's
Wild Bill
Nov 6, 2011 09:02 PM
8541Hawk
Oct 2, 2010 06:25 PM
yruyur
Feb 8, 2010 10:44 PM
Slim
Mar 10, 2009 08:00 PM
YAMAROCKET630
Feb 22, 2006 02:04 AM
