"Fire diagrams"
Old Aug 17, 2005 | 11:12 AM
roadrun_fr's Avatar
roadrun_fr
"Fire diagrams"
After posting for "finding the right TDC" here is a diagram of how it goes :
Each step here :
Any errors ?
Old Aug 17, 2005 | 11:41 AM
roadrun_fr's Avatar
roadrun_fr
Re: "Fire diagrams"
with this diagram, "good" TDCs are easy to find :
Search for compression and check FT at the crank : you are at the "good" TDC for the front.
Turn 3/4 turn (270°): you feel another compression and check RT at the crank : you are at good TDC for the rear.
OR :
Search for compression and check RT at the crank : you are at the "good" TDC for the rear.
Turn 1 turn 1/4 : you feel another compression and check FT at the crank : you are at good TDC for the front.
Simple no ?
Old Aug 17, 2005 | 11:46 AM
jschmidt's Avatar
jschmidt
Or, you could just take off the valve cover.
Old Aug 17, 2005 | 12:09 PM
roadrun_fr's Avatar
roadrun_fr
Re: "Fire diagrams"
Yep ! It works too :wink:
Don't you think it's the way that professional mechanics use to change CCTs ?
Old Aug 17, 2005 | 11:58 PM
bluesman's Avatar
bluesman
Yes, but changing CCT without removing cover is way faster, and to reinstall cover properly you need torque wrench and sealant if cam cover seal is not new...
Tried both ways back then and I prefer to do not touch cover....thou I used more dangerous methid of finding god TDC, so it's great to have those diagrams....
hondahawk
Dec 10, 2014 01:27 PM
Little_Horse
Sep 9, 2009 07:14 PM
haknslash
May 18, 2009 03:26 PM
saxman
Jun 21, 2007 05:11 PM
spekbikes
Apr 30, 2007 10:08 AM
