Engine Noises
Old May 13, 2005 | 05:42 PM
DameDiggler's Avatar
DameDiggler
Engine Noises
When listening to my bike, I hear a ticking noise. If I rev motor, ticking increases linearly with throttle. I hear that V-twins make a lot of noises, but curious as to what this is. Even when I adjusted the tensioners, the noise was still there. I was curious if anyone else has a noisey VTR or what the deal is. Any suggestions to fix???
Old May 14, 2005 | 04:30 PM
mikecronis's Avatar
mikecronis
Re: Engine Noises
I believe this is actually the valves ticking. This is normal.
Old May 21, 2005 | 12:38 AM
DameDiggler
Re: Engine Noises
Can you please elaborate on why valve ticking is normal? Although,... I have heard that v twins make odd noises; it just seems like clatter and erks me a little not knowing what it is. If its normal, hopefully aftermarket exhaust will silence it! That's next.
Old May 23, 2005 | 11:43 AM
NOrrTH's Avatar
Re: Engine Noises
Mine doesn't tick. There's lots of whirring gear noises though.
Old May 23, 2005 | 02:38 PM
jschmidt's Avatar
jschmidt
Some do, some don't. This is a common complaint on all bikes.
If the valves are in spec, the ticking noise is normal.
Old May 26, 2005 | 10:39 AM
mikecronis's Avatar
mikecronis
Re: Engine Noises
The ticking shouldn't be omnipresent. I find on bikes I've had that are V-Twins (Ninja 250, Ninja 500, Superhawk, CB450) that the noise doesn't increase and the stock muffler sound and Jetson's-sounding engine drown out the ticking almost completely after 2500 rpm. I would suggest a valve check at the dealer (it's a bit tricky) if you can hear it above 3k rpms.
I have some pretty darn good hearing and can tell subtleties pretty well in engine sounds and things.
If the ticking gets more intense as you ride uphill under low rpms with throttle openned up decent it could be "knock" meaning you're using crap-gasoline from convenience-store gas stations (ie. not Conoco, Sunoco, Union 76, etc.) or too low an octane. I'm pretty sure the SHawk needs 87 octane minimum. I tend to use 91 (which is a tad high, though unlikely detrimental at 4-points above suggested, though 93 octane might be bad) (Uh-oh, I hope I didn't open an octane forum war here..)
If the ticking is drowned out by wind noise and engine/muffler noise at 3k rpms, you're good.
Simpleton
Aug 30, 2015 09:52 AM
KCCO
Jun 14, 2013 11:24 AM
offroad_rider2008
Aug 8, 2012 06:51 AM
MisfitToy
Jun 5, 2008 05:47 PM
nfbzike
May 6, 2008 06:24 PM
