EBC Clutch Discs Suck!
Old 11-28-2009, 12:00 PM
Brooks' Cycle Centre'
superchickencornermonster's Avatar
superchickencornermonster is on a distinguished road
Just a quick warning...
I had 36K on my 03 when the clutch started to slip. I put in the EBC kit to save a few bucks. I broke them in the way that you are supposed to, but here we are at 39K and they are starting to slip and get VERY grabby at high rpm controlled slips. I took them out and found that they were already burnt. New Honda plates on the way.... Anybody else have this problem?
superchickencornermonster is offline
Old 11-28-2009, 12:18 PM
When I decided to freshen up the clutch on my VTR (75K+ miles), I did a bit of research and opted for stock fibre plates (and aluminum Hyperplates for reduced rotating weight and improved engine response) based on negative feedback I found on non-OEM brands. Incidentally, my clutch was still in perfect shape; I was looking for a reason to put the Hypers in....
mikstr is offline
Old 11-28-2009, 12:57 PM
revhead1957's Avatar
revhead1957 is on a distinguished road
Was there a significant price difference?
revhead1957 is offline
Old 11-28-2009, 01:49 PM
mboe794's Avatar
I had a very similar experiance with EBC a few years ago on a MX bike.
mboe794 is offline
Old 11-28-2009, 01:53 PM
gixxerjohn's Avatar
gixxerjohn is on a distinguished road
weird i had ebc on a land speed pass on my 1k with no probs
gixxerjohn is offline
Old 11-30-2009, 07:57 AM
Maybe $20 or $30. Not much, at certainly not worth it.
Old 11-30-2009, 07:58 AM
Your 1K? Would that be a 1K Gixxer? Cuz' if it is, you have to remember that the torque output for the Hawk is considerabely more than a Gixxer 1K, depending on the year and mods, of course./
Old 11-30-2009, 08:01 AM
umm, NO!!!!!!! the Gixxer (any year) makes significantly more torque than the VTR. Given its more regular firing order (an I4), it produces it in a smoother fashion however (fewer big pulses).
mikstr is offline
Old 11-30-2009, 12:33 PM
bristunt's Avatar
bristunt is on a distinguished road
I have an EBC in mine, changed simply because I had to change the clutch cover. Mine had 60k miles on it and the plates were still fine!
Put the EBC's in anyway. It drags when cold. Need to let it warm up before putting it in gear the first time.
Wouldn't recomend them.
bristunt is offline
Old 11-30-2009, 01:19 PM
gixxerjohn's Avatar
more then mine? hahaha mmm no
i make 112ft/lbs
im sure its more then a superhawk
Old 11-30-2009, 01:33 PM
NCDave's Avatar
i make 112ft/lbs
Oh stop braggin!
NCDave is offline
Old 12-01-2009, 07:12 AM
i make 112ft/lbs
This is why I said "Dependig on the year and mods, of course".
Old 12-01-2009, 07:14 AM
You need to do some SERIOUS mods to a VTR for it to get anywhere near the output of a stock GSX-R (and even then, you may get close on the torque but the higher revving Zook will still blow it away in hp, regardless of the year you choose).... I love my VTR but to say it comes close to a GSX-R power-wise is delusional....
mikstr is offline
Old 12-01-2009, 07:23 AM
Actually, it seems that I need to be corrected on this....
Turns out that the last time that the SuperHawk beat the Gixxer 1000 was in 1997 and they were pretty much even. So, I apologize for the misleading information. So, in short.... I don't know why your clutch discs worked for the Gixxer and not for the SuperHawk. Maybe it has something to do with the weight ratio. Does the Gixxer have a hydrolic clutch or a Cable Clutch?
Old 12-01-2009, 07:26 AM
Agreed. I just checked. BUT, I do have 118 hp at the rear wheel with 83 ft lbs of torque, according to the dyno that I ran last year. Not bad, anyways.
Old 12-01-2009, 07:43 AM
if those numbers are for your VTR, you either have a lot of mods, or a very optimistic dyno....
mikstr is offline
Old 12-01-2009, 08:06 AM
gixxerjohn's Avatar
there was no gsxr 1000 in 97
Old 12-01-2009, 08:07 AM
gixxerjohn's Avatar
also cable clutch
Old 12-01-2009, 09:35 AM
Alright, now I'm just feeling dumb. Again, you are right. It was the 1100, not the 1,000.
GSX-R 1100 1997 (U) Overall Length: 2 130 mm (83.9 in) Overall Width: 755 mm (29.7 in) Overall Height: 1 190 mm (46.9 in) Seat Height: 815 mm (32.1 in) Wheelbase: 1 485 mm (58.5 in) Ground Clearance: 130 mm (5.1 in) Dry Weight: 221 kg (487 lb) Engine type: 1 074 cc Water-cooled inline-four, DOHC, TSCC, 16 valves. 156 hp (117 kW). Measured (USA): 122.6 bhp (91 kW)/ 9.250 rpm, 75.0 ft·lbf/ 7,000 rpm
Old 12-01-2009, 09:36 AM
I've done a lot to my bike. I documented the whole process, so I'll probably put that in the mod section later on, if you are interested.
Old 12-01-2009, 09:38 AM
also cable clutch
It's weird how some bikes warrant a hydro clutch and some don't. Obviously power is not the issue. Any thoughts?
Old 12-01-2009, 10:15 AM
the type of disengagement mechanism has absolutely nothing to do with the clutch`s ability to handle power. For example, while many Victory cruisers use a cable-actuated clutch, others use hydraulic, and owners can "upgrade" a cable unit to a hyd system (kit sold in accessory catalogue), the only difference being the means of transmitting the motion to the clutch, the plates, springs,... are exactly the same.
mikstr is offline
Old 12-01-2009, 10:21 AM
Yes, I understand that. But, I was uner the impression that the reason you put a hydro clutch on a bike is because of the high strength of the springs. The reason that the srpings might be so strong is, of course cuz' they need to be able to hold the discs together more tightly due to more power. Thoughts?
Old 12-01-2009, 10:24 AM
and btw, would love to know what you did to your bike to get those kinds of numbers (especially the torque, quite impressive)
mikstr is offline
Old 12-01-2009, 10:28 AM
Yeah, It took me the whole winter, but it was well worth it. I took pictures of the whole process and wrote a little mini-story about it. When I took it to the dyno, I was very happy. I've always wanted an RC-51, but the ergos were just not good for me, so i wanted the next best thing, and now with the powe that I have, it feels alot closer.
Old 12-01-2009, 10:39 AM
as the curiosity is killing me, could you post just a quick overview of what you did? I am in search of similar numbers (my last dyno run had me making 113 hp and 71 lb-ft although airbox box mods carried out since then should have me slightly over 115 hp and 73 lb-ft, based on the dyno results I had obtained previously with the same mods). This, of course, is on a bike with over 75,000 miles on teh odometer. I will be freshening up the engine with OS JE pistons in the foreseeable future and hope to get up to @ 122hp and 80 lb-ft. I am intrigued at your 83 lb-ft, however......
mikstr is offline
Old 12-01-2009, 10:43 AM
Stevebis1's Avatar
^^ So if you got this written up, hurry up already and post it! There are guys here that would trade their GF or wife for 83 ft-lbs (maybe even buy untested velocity stacks? )
Stevebis1 is offline
Old 12-01-2009, 10:47 AM
of course some of us have tested and proven stacks and are very happy with them BTW....
mikstr is offline
Old 12-01-2009, 10:52 AM
Stevebis1's Avatar
Just pokin at you. If that Doc Honda fellow gets up and running I'll likely be near the front of the line. Course then i'll have to get a Flo Commander too...
Old 12-01-2009, 11:12 AM
It`s all good Am curious to see how one gets 83 lb-ft out of a VTR though (although I seem to recall Shayne`s buddy getting similar numbers with his M4 full system)...
mikstr is offline
Quick Reply: EBC Clutch Discs Suck!
