Driving lights
As the weather warms up here night riding is very much on the agenda.
Does anyone have any suggestions for a good set up. I am not looking to upgrade the headlight, more for some discreet driving lights that give good vision on the open road at night. Thanks. |
Originally Posted by kenmoore
(Post 392111)
Does anyone have any suggestions for a good set up. I am not looking to upgrade the headlight, more for some discreet driving lights that give good vision on the open road at night. Thanks. , same guy has a 2010 Tiger 1050 with Krista 2 lights .. Loves them both Pricy ...but very high quality. Ive also tried the cheap ebay LED lights..on a DRZ440 SM build, They are what they are, low quality but they do put out light....I spent an hour modifying the designed mount to get something that was steady ...the way the cheap light was designed to mount wiggled from the get go, and would have fallen apart in sort order |
Thanks Mr M.
Driving Light Mounting Design
10 Attachment(s)
I installed twin 50w halogens a dozen or more years ago but the way I mounted them is what I'm sharing. I want to replace the lights themselves with LED units but have not found any as small, light weight or with a beam comparable to the halogens that will adapt easily to my mounting tubes, and have evaluated many including the Clearwater offerings and am still searching.
(Post 392159)
Waiting for a Direct bolt replacement light onto a custom mount you made for what is a non industry standard fitment...might be a long wait. |
(Post 392160)
Im not seeing the issue?? Most any of the lights I have installed (more than a dozen brands or models) would install using the mount you have, or a slight adaptation.
Hey Skokievtr,
Thanks a bunch mate. The way you have mounted the lights is what I was thinking. I have nothing against halogen lights. I wonder if LEDs are really that much better. Thanks once again. Your pictures have been a great help in so far as I now know that I can mount them through the air inlets. The pictures of your bracket schematics is a bit blurry but I get the idea. Great stuff! Now all I have to do is source the lights, switch gear and relay. |
2 Attachment(s)
Maybe you can see these sketches better
Check out these incandescent DL which use a standard H2 bulb but IMO are too heavy to cantilever out the fairing nostrils without a secondary support for the strut... HELLA INC 88157 OPTILUX 962 SPOT HID LOOK LED draw much less amps which the VTR with only 280 watt output is amperage challenged (see my other posts regarding what can be run simultaneously) are smaller, lighter and depending on the diode put out an incredible amount of white light. These are 2 I'm considering https://www.superbrightleds.com/more...Specifications 2" Round 10 Watt LED Mini Auxiliary Work Light Part Number: AUX-10W-Rx $49.95 https://www.superbrightleds.com/more...Specifications 10W Mini-Aux, 2" Modular LED Off-Road Work Light Part Number: AUX-10W-Sx $34.95 I'm considering several but it's how the attach / mount that to me is critical.
(Post 392258)
Hey Skokievtr,
