Drive Train/Sprocket Preferences?
Time for some Spring cleaning now that time has changed.......went for a ride yesterday and adjusted my chain......it's now stretched to the limit....time for a new chain and sprockets, probably need to drop in new cush drive blocks too (seems to me they were pretty worn when I put my last rear tire on......should've done it then but too lazy)......
Anyway, I've always just run the stock sprocket size.......What are you running?........Just wanted to take an informal pole to see if there's a trend/preference for changing up the sprocket size..... Likewise, is there a specific chain preference? |
-1/+1. Equivalent to +2 1/2 on the rear. Usually whatever X-ring chain I can get the best deal on whenever I have to replace one.
15 front 43 rear
+1
15 front 43 rear haven't done it yet, but as soon as i can it will be done because i was looking at y chain today and i can see where a rivet is about to come.....bummer i was going to ride today..........it's south Ga here weather is perfect. |
Don't bother with an alluminum sprocket, go with steel. The vortex alum sprocket that I had lasted about 4K miles and it was DONE.
good input so far.....keep it coming.....
Originally Posted by divingindaytona
(Post 204348)
Consensus (so far) seems to be to opt for more zip (drop a tooth up front) and less top end (add a tooth or teeth in the rear).......makes sense.......I dont need to go over 100mph anymore (my track days are behind me)......and the front end will feel even lighter with one tooth less up front......not sure why I haven't screwed around with sprocket sizes before now (~39K miles on the bike!).....I change'em up all the time on my dirt bikes.... Has anyone used aftermarket cush drive blocks in their hubs? (Not sure if there even is such a thing but thought I'd ask.....) |
I have a set of sprockets from sidewinder. The trimetal rear with the steel front. I wouldn't get the trimetal again, but the full titanium rear will give excellent life. I did not like their chain at all, so substitute with whatever. I have gone through two chains with that set of sprocket and it doesn't seem to wear very much.
Originally Posted by Crawdaddy
(Post 204350)
Agreed - I always use steel, even on my dirtbikes.....aluminum rear sprockets wear out too fast.....
I Just moved into the "Replace Chain" indicator on mine also . I am pretty happy with the stock gearing for what I am using my bike for. I have been doing more touring than sporting lately . LOL . I came across this on Ebay ...http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem= I know you get what you pay for , But has anyone purchased this set up from this guy ???
Did the 520 conversion with 15/43 sprockets... So far so good.
2 Attachment(s)
(Post 204364)
It's a win/win with shorter gearing if you can stand the extra revs and buzziness.
Attachment 29717 Attachment 29718 |
Gold
530 ek zzz chain/jt sprockets 15/43 |
