Curious About Calipers
2 Attachment(s)
I got to lookin' at the front calipers on the CheeperHawk today, thinkin' that they were an upgrade from the stock units. Based on a post by "lazn" from a while back, where he listed a bunch of Honda caliper specs, I pulled them off to measure the piston sizes figurin' that would be helpful if I needed rebuild kits or new pads.
Surprise! The calipers on the bike had 30mm/27mm pistons....same as the OEM SuperHawk units! I dug out a pair of '02 CBR F4i calipers (bought to eliminate the linked brakes on a VFR I used to have) and checked them out...34mm/32mm, just like "lazn" posted. CBR caliper install comin' up!! The 1st pic is the "upgrade" caliper that was on the CH, the 2nd is the CBR unit that will be mounted up most ricky-tick. Rex Attachment 28137 Attachment 28138 |
Good catch! F4i calipers are SO much better than stock.
Someone must have painted your OEM ones at some point. edit: I have my OEM ones still and I think they look different than what you have. hmm.. I will dig them out and double check this weekend, unless someone else has easier access before then. |
Originally Posted by lazn
(Post 248452)
Such a great upgrade... do you have a m/c to go with that too? |
1 Attachment(s)
(Post 248454)
Nah, they were black from '01-up.
......do you have a m/c to go with that too? They must be later versions, no evidence of being painted. Master cylinder? Yeah, we got that! I have a pretty serious aversion to the "urine sample cup" reservoirs, even more serious when they're mounted on standard handlebars. Rex Attachment 28135 |
Um... NOooooO... Bad modder... Put the hammer back in the toolchest... It's not used for wrenching on bikes...;)
Like the looks of that... |
(Post 248473)
(Post 248478)
A hammer and a looooong screwdriver are all anyone needs to work on anything.
Is this the equation? You mount the triple that much deeper on the tubes so you can install superbike bars to raise the ride position up? Am I missing something? You're just adding parts to change no geometry. Or am I missing something?
Originally Posted by nuhawk
(Post 248486)
(Post 248473)
The hammer I use on the bike is much heavier and made of steel!! :p
(Post 248486)
The fork tubes are protruding through the upper clamp as needed to mount the clip-ons. I haven't changed the original geometry at all. The superbike bars just make the riding position a lot more tolerable for an Ol' Geezer like myself! Rex |
Originally Posted by bjorn toulouse
(Post 248465)
Master cylinder? Yeah, we got that! I have a pretty serious aversion to the "urine sample cup" reservoirs, even more serious when they're mounted on standard handlebars. Rex http://i721.photobucket.com/albums/w.../superbar3.jpg |
1 Attachment(s)
Yes, stock upper clamp. The risers are '02 Yamaha FZ1, 50+-mm rise.
I threaded the mount studs about 25mm down and cut off about 25mm of the overall length. On the bottom of the upper clamp I spot faced the casting to allow use of a 6mm spacer, about 30mm in diameter, as a bit of reinforcement. Here's a pic of the risers from the Ebay listing. Rex Attachment 28128 |
Hoenstly guys, I didn't notice a single change when going to the 'better' calipers. Maybe it was just me, but the braking power was pretty much the same. FYI - I changed out the master cylinder too. Just thought I'd throw that in for discussion.
(Post 248518)
I second that... BIG improvement in feel and function when I switched to the F4i setup.
(Post 248518)
Me too. I persisted with the standard calipers and master cylinder for ages and ages. Mine were rebuilt, nicely painted, and had new pads and bolts etc, so I was reluctant to take them off. I spent heaps of time bleeding them, confident I could get them good enough.
But I just couldn't!!!! F4i calipers and master cylinder swap, and immediately I had two finger braking that gave me great confidence. I have done a lot of mods to my bike, and for me, this is the best mod I have done. |
