Crankcase Gasket Replacement
Is it possible to replace the crankcase gasket without removing the engine from the frame? It seems like a have a small leak, or rather a weep, back be the shock linkage. If the gasket can be replaced be dropping the oil pan and lower half of the crankcase without disturbing the crank or transmission, that would be great. Otherwise I think I will live with it.
Another Wisconsin fellow. Where abouts are ya?
As to your question, if you're not exactly sure where it's leaking from, then you can get a dye that you put in the oil and use a black light to see where it's truely leaking from. |
To answer the question, it cannot be split without taking it out of the frame.
IN response to both responses..... :lol:
First: An option other then trace dye and a special light source is to degrease the engine, then use a spay can of dry type foot powder, spray the entire suspect area, and HIGHER. Go for a short ride.. your oil leak will reveal itself at the source. Second: Agreed, you can not do what your contemplating... engine has to come out. |
I kind of figured the engine would have to come out, just thought I would ask anyway.
It's not that big of a leak, there is a little residue on the back of the case. It's not dripping out or anything like that. I think I'll just leave it, not worth pulling the engine. I will try the foot-powder or dye trick just so I can pin-point it. CruxGNZ - Right down the road from you in Muskego. |
Maybe it's coming from the CCT?
Originally Posted by superrst
(Post 364019)
E's foot powder idea is cheaper and easier than using dye and a blacklight, so with such a small amount leaking, I would use his method. |
Nice to see im not the only hawk owner in se WI, im in Kenosha just south of Milwaukee, maybe next season we will have to set up some riding time, love the looks I get when people hear my hawk with the 2 bros titanium pipes.
If we could get all the Superhawks from this forum for a ride, that would be cool. By my count, there is at least a dozen in S.E. Wisconsin now.
Yeah, the sound! :) My family just brought that up the other day. They all own Harley's and each one of them said they can tell when I pull up in the driveway or even driving past thier house, because it's a totally different sound. I tried explaining to them why that is, but I couldn't word it well enough (we had a few drinks at the end of the night) and needed to draw it on paper and promptly lost thier attention haha |
I did the foot powder trick and took a short ride(it started to rain just as I was warming the bike up). Pretty cool idea.
Yeah, we all should do a ride. I think time has run out this year though. I think Indian summer has come and gone. John |
Ok, I got a little confused when reading this thread:
- The original post was referring to replacing a crankcase gasket. No such gasket exists. - There was some discussion of removing the engine from the frame. The only gaskets that can be replaced are possible with the engine in place. I think it would be really helpful to clarify where the leak is originating because the conclusions above are making a lot of assumptions. Just my 2 cents! |
To clarify:
I have some oil on the bottom-rear of my engine and a small spot in the belly pan (after-market). It looks like it could be the crank-case gasket, but I'm not sure. Are you saying where the combination crank-case transmission splits, their is no gasket? |
(Post 364331)
To clarify:
I have some oil on the bottom-rear of my engine and a small spot in the belly pan (after-market). It looks like it could be the crank-case gasket, but I'm not sure. Are you saying where the combination crank-case transmission splits, their is no gasket? (and that is what I think Jamie is referring to, though he would have to confirm) Sealant is used at the case halves. gas·ket noun \ˈgas-kət\ : a piece of rubber or some other material that is used to make a tight seal between two parts that are joined together. So yes, Case sealant (what ever brand and style you prefer ThreeBond 1104, Yamabond 4, Honda Bond 4 or HT, or what ever) is the method of forming a gasket at the case halves. |
Before you dismantle the engine - have you checked sprocket area for leaky clutch fluid?
(Post 364331)
Since this thread has already been hyjacked...
Originally Posted by jagg1174
(Post 364074)
Originally Posted by CruxGNZ
(Post 364075)
(Post 364267)
Yeah, we all should do a ride. I think time has run out this year though. I think Indian summer has come and gone. John I'm 45 minutes south of Kenosha and ride SE & EW WI every weekend I can. PM me, I'm riding one day this weekend depending on which day is better. |
