Converter unit wires
Made a mistake and lost wire order on my wiring harness plug that goes into converter unit.
Here's what I think is right and plugged in now. Clip side Nothing. Blue/yellow stripe. Nothing Black/blue stripe. Green. Yellow blue stripe Pictures or confirmation on your bike would be great. I've been scouring forums and can't quite get a good enough look. Want to be real sure to not fry my stuff. Thanks |
1 Attachment(s)
Does this show enough?
Ok sorry thought that was good enough. When I went to do it I had a hard time telling difference between black yellow and black white. White look to be on same row of 3.
Here's what I think is right and plugged in now. Clip side Nothing. Blue/yellow stripe. Nothing Black/blue stripe. Green. Yellow blue stripe Also has anybody soldered connections directly to the connectors on the converter unit? Seems very fragile from what I've read. So any confirmation or pictures would be great. Got conflicting info from another thread I read. I have a 99 hawk |
If you mean not use a connector dont do it. Unless you are stranded on a trip you should track down the proper connector or at least individual plugs. Try molex or corsa websites. One of them has that plug.
I have connectors that fit very tight. Thinking of soldering that on. Trying to make it good as possible. Looking through those websites not having much luck tho
Can someone please look. I'm unable to ride until I get this figured and I've looked everywhere!
Tell me exactly where this is again?
Right underneath the seat. It's a squarish black box with a 6 pin connector.
Should be 6 inches from icm. Much appreciated. Don't wanna fry my bike. Was a out rdy to throw a shot in dark |
Ok going to look. May take a minute my baby is crying
I cant see it but my whole tail is modded. Plastic all hacksawed out and sheetmetal trunk installed, as well as an alarm and extra fuse box so maybe just too cluttered
When I get to my SH I will take a look at it.
The way I remember the connector only goes on one way. Did you completely get rid of the connector? |
Yea at the very base of the plug on the wiring harness I had an exposed possibly burnt wire. I had it all hooked up but decided to secure it better but forgot I had to keep the plug or wiring there to know order.
Lol I even kept it around just incase I needed to check wire order until I tried to "rebuild it" |
1 Attachment(s)
Ok got a picture from my 1998 and wrote down the wires in order.
Attachment 22696 In the orientation shown in the picture: wires top row-------1 2 3 the plug------------O O O --------------------O O O wires bottom row----3 5 6 1. Black w/yellow tracer 2. Blue w/yellow 3. Black w/white 4. Black w/blue 5. Green 6. Yellow w/blue Hope this helps. |
Yes thanks. Hooked back up and securing!
