Constant power wire
1 Attachment(s)
So I am installing an aftermarket dash. I need a constant 12 wire behind the dash cuz it has a clock I want to work.
Is there any constant power wires behind my 98 dash I can tap into? Yes I can test em all but maybe someone knows |
I wonder if you can redline on that tach lol
Paging tweety... |
If you disable the rev limiter, you can redline it at 13,000 rpm. once.
(Post 331560)
Is there any constant power wires behind my 98 dash I can tap into? Yes I can test em all but maybe someone knows The red wire going to your ignition switch is also hot except direct to batt +, no fuse. |
Thanks cranken, thats what I was looking for.
Less thanks to the charlatans using my thread to babble...... Pics to follow on install |
Sorry for the free bump since I was curious too but didn't know, won't happen again.
| All times are GMT -7. The time now is 10:09 PM. |
