Clutch slipping???
Help...
my 99 SH started clutch slippage at higher RPMs but eventually I couldn't get out of first gear. So I decided to replace the clutch (drive and friction plates; and springs) with Barnett'. Additionally I decided to rebuild the slave cylinder. Went to ride it today and slight improvement but the clutch continues to slip badly anything I'm missing? Do I need to replace the clutch basket too? Only 20k miles on the clock |
Are you 100% with the re-assembly of the new parts? Did you remove the actuator rod from the slave to the clutch? If so did it go back with the correct orientation? Is the clutch lever adjusted correctly? Do you have aftermarket levers? If so they can sometimes apply some pressure, even though it seems to be adjusted correctly.
Thanks for the list....I'll have to get back in there to make sure the install was correct. If they are all confirmed...what is my next step to consider?
The last friction plate seats into different notches in the basket. If this is done wrong, the clutch will not work properly. Though I don't know what the issues will be. Maybe someone will chime in a offer some advise.
Originally Posted by xeris
(Post 416190)
I don't think I checked the plate thickness when I installed them... Would that affect the slipping? |
Originally Posted by Tripleplay707
(Post 416191)
I remembered being careful to put the last plate as you described.
I don't think I checked the plate thickness when I installed them... Would that affect the slipping? https://www.superhawkforum.com/forum...ett-oem-32406/ |
Any chance you recently installed a different lever? When was the last time your hydraulic system was fully rehabbed?
(Post 416196)
Also get that master cylinder rebuilt and meticulously cleaned.
[wait... Where to buy clutch MC rebuild kit??
QUOTE=Wolverine;416321]Also get that master cylinder rebuilt and meticulously cleaned.[/QUOTE] |
Jeez. 10 seconds.
I would opt for the OEM from Partzilla. https://www.google.com/search?q=hond...t=gws-wiz-serp |
thank you! we're spoiled here :D
(Post 416327)
Jeez. 10 seconds.
